PCV Valve problems...I think?
Old Jul 27, 2005 | 10:46 PM
egerdahl's Avatar
Default PCV Valve problems...I think?
I have a 2nd gen. integra with a B18A1 and I am rebuilding the engine. When I was removing the intake manifold I noticed that there was a small box underneath the manifold and there are two hoses going into it. One hose leads into the crankcase and the other goes into the bottom of the intake manifold but the hose going to the manifold was never hooked up. Would that be why the car never did idle very smooth and could that have led to any major problems that I would need to concern myself with... Thanks
Old Jul 27, 2005 | 11:07 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: PCV Valve problems...I think? (egerdahl)
A problem with the PCV system could definatly lead to a bad idle.
Old Jul 28, 2005 | 07:49 AM
phyregod's Avatar
Default Re: PCV Valve problems...I think? (JDM_Ej)
yeah, concern yourself. then fix it.
That hose can only be ordered from the dealer, it goes from the black box up to the PCV valve, and has a cup molded into it. Its not just a normal hose.
That hose gets brittle and if you aren't very careful disconnecting it, the cup just snaps off. (look at your manifold, if your pcv valve is still attatched to it, the cup broke off. Its the thing that holds the PCV to the Manifold.
Old Jul 28, 2005 | 02:55 PM
LudemanDan's Avatar
The PCV valve is the plastic thing that plugs into the valve cover.
Old Jul 28, 2005 | 06:30 PM
michael O's Avatar
Default Re: (LudemanDan)
On a b18a the pcv valve is between the runners on the intake manifold near the flange.
RiversideS13
Jul 18, 2007 11:08 AM
Enta
Jan 29, 2007 03:51 AM
crexer
Mar 19, 2005 08:27 AM
Nextelbuddy
Mar 26, 2004 05:08 PM
NeXtLeVeL_TyPe_R
Dec 4, 2002 10:44 AM
