Window off track.
I'll tell you how to fix it this time, but before you ask questions next time, search. I've told people how to do this numerous times.
take off the speaker cover and remove the 3 screws that hold the door panel to the door out. Next grab the door panel from the rear and start pulling, the panel is held on by clips that will make a poping sound when pulled out. Don't be affraid to pull. Now disconnect the plug to the speaker and find the 10mm bolt that holds the window track to the door. Take the bolt out and reach inside the door and find the window and put it back inside the track (oh yea, make sure the window is ALL the way down) You can spray some silcone lubricant into the track to avoid this from happening again. Push the window and the track as hard as you can and put the 10mm back in and tighten it down. Now put everything back in the reverse order and you are done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 »</TD></TR><TR><TD CLASS="quote">Take off your door panel and fix it. Is this a 96+ Civic? those cars i think are known for window issues</TD></TR></TABLE>
yes omfg. my 00 si is horrible. it has came off the track completly 3 times. any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">yes omfg. my 00 si is horrible. it has came off the track completly 3 times. any ideas?</TD></TR></TABLE>
I just posted one. Silicone lubricant. And don't slam the door shut with the windows down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
I just posted one. Silicone lubricant. And don't slam the door shut with the windows down.</TD></TR></TABLE>
that may do it... thanks
icefirezero
Jun 13, 2004 04:03 AM
