ABS PROBLEM
I was bleeding my brakes, and when I bleed the hydrolic modulator, I didn't realize that your suposed to add fluid to the abs resivior, I thought it would refill itself from the brake fluid resivior. Anyway, I allowed the abs resivior to run dry then my abs light came on. I then saw the cap that I should have been pouring brake fluid into as I was taking it out. I filled it and continued to bleed the system. The abs light turned off. However, when I drive my car a buzzing sound comes from the hydrolic modulator, and after driving for about 15 minutes the abs light comes on. Does anyone have a solution to my problem.
SpeedFreek34
Jul 22, 2007 05:43 PM
