Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\
Old Jul 27, 2005 | 01:47 PM
SECURITY's Avatar
Default Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\
Like an idiot I cleaned my IACV a while back by taking it out and letting the whole thing sit in carb cleaner for several hours. When I went to hook it back up in the car... coolant spraying everywhere. Turns out this little rubber gasket got expanded in the process, and now I have a perfectly good but perfectly useless IACV!!
Just wondering what I should do... or where I could possibly get this gasket:
Also aluminum foil makes a great gasket but I don't plan on living like this forever.
Old Jul 27, 2005 | 01:50 PM
Hapexamendios's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (oh_crx)
rtv sealant maybe?
Old Jul 27, 2005 | 01:56 PM
SECURITY's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (Hapexamendios)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapexamendios &raquo;</TD></TR><TR><TD CLASS="quote">rtv sealant maybe? </TD></TR></TABLE>
more info?
Old Jul 27, 2005 | 02:21 PM
Redline96LX's Avatar
* B A N N E D *
order one online, or go to the dealer, its rubber (or paper?) and costs like 3 bucks at the most.
Old Jul 27, 2005 | 03:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_crx &raquo;</TD></TR><TR><TD CLASS="quote">more info?</TD></TR></TABLE> just the tube of sealant from like walmart... or honda bond as most of HT would say
Old Jul 27, 2005 | 03:45 PM
Agent_STFU's Avatar
Banned
Hahaha, I am loving the tin foil gasket. So cheap, I used to be the same way. Instead of running a catalytic convertor, I kept wrapping my 2nd 02 in tin foil and sticking it back in the 2nd bung in the header.
Old Jul 27, 2005 | 04:45 PM
SECURITY's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (Diseased Dreams)
Some helpful responses so far.. I'll have to look into this so-called honda bond. I definately can't go to the dealer with this because I'll strangle someone if they ask me for $100,000,000 for a new IACV heh.
If someone else has dealt with this or knows where exactly I can order the rubber piece online that'd be clutch.
And yes tin foil is the sheit for gaskets.... exhaust manifold etc etc etc it has endless ghetto applications
Old Jul 27, 2005 | 04:51 PM
xEnderx's Avatar
Get teh gasket from Honda. DO NOT USE HONDA BOND!!!!! You'll never get it off again.
Old Jul 27, 2005 | 07:59 PM
kkim's Avatar
year, model, trim level of your car?
Old Jul 28, 2005 | 01:26 PM
SECURITY's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (kkim)
^ I have a d16z6 fully converted to obd1 inside of a CRX chasis. I'll probably go this week or next to the Honda dealership () if no one knows of a place to order online.
Old Jul 28, 2005 | 02:06 PM
HondaPartsHero's Avatar
Technical Hero
Our price (www.acuraautomotiveparts.org) $1.83
this is for an ls integra but I'm sure pretty similar to what you need, just find your model of engine and order one for that one
Old Jul 28, 2005 | 02:09 PM
Agent_STFU's Avatar
Banned
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (yebabee)
awesome, there you go right there
Old Jul 28, 2005 | 02:22 PM
JDM-97CX's Avatar
Personnaly I'd just use silicone. Go to a parts store and but Permatex's product "The Right Stuff: For Imports" It works great as a gasket maker. I did my oil pan with it about a year and a half ago and no leaks yet.
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee &raquo;</TD></TR><TR><TD CLASS="quote">#22
this is for an ls integra but I'm sure pretty similar to what you need, just find your model of engine and order one for that one</TD></TR></TABLE>
I don't think he is looking for #22 though. He does not need the one that goes against the IM he needs the one that is on the bottom where the two coolant tubes are attached. Look where he has the foil in his pic up above.
Old Jul 28, 2005 | 03:54 PM
Technical Hero
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (ralphie14)
what engine is it for? I may have one laying around in some extra intake manifolds I have, I'll send it for free.
Old Jul 28, 2005 | 05:23 PM
eg crunkmonster's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Get teh gasket from Honda. DO NOT USE HONDA BOND!!!!! You'll never get it off again.</TD></TR></TABLE>
i dont know what you're talking about.....hondabond is strong but it does come off.....just buy new gaskets (if they sell them) or just hondabond (kinda expensive) or use RTV sealant, the grey kind
Old Jul 28, 2005 | 05:26 PM
mike1114's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (eg cookiemonster)
Permatex ultra grey.
U can get it at vatozone, discount, pep boys, any auto parts store.
Makes great gasket. You can get if off if needed also. Its like hondabond.
Old Jul 28, 2005 | 06:53 PM
SECURITY's Avatar
Default Re: Help! Dunked IACV in carb cleaner = Expanded IACV gasket :-\ (mike1114)
Thanks everyone The diagram yebabee provided is very helpful even if it's not #22. I think I have all the info I need now so thanks again! payce
Old Jul 28, 2005 | 10:21 PM
kkim's Avatar
I would strongly suggest getting a gasket from Honda if one is available. Using a gasket sealer/material might not be a good idea unless you know exactly what product to use. I do know many RTVs are not gas proof and will break down on contact... learned that the hard way using some back in the old days of dirt bikes and using RTV on the intake manifold side.
With regard to the original gasket swelling up, I had a similar problem when I used gasoline to clean some brake calipers. Caliper piston gasket swelled up so much I couldn't get get it back into the bore. I was screwed as I could not find a caliper rebuild kit locally. Much to my surprise, the gasket shrank back down to size in a few hours after the gasoline evaporated from the gasket material. I reused the gasket and the brakes are working fine today w/o leaking.
Bottom line... watch what you expose the gaskets to. Without knowing what material they are made of and what solvent to use, very bad things can happen.
Good luck... hope a new gasket solves your problem.
Morasso
Feb 3, 2008 10:00 AM
actionfigure
Jan 7, 2007 07:06 AM
Inline6 Silvia
Oct 30, 2006 08:37 AM
skater5067
Apr 22, 2005 08:24 AM
gtowni3
Oct 8, 2004 08:30 PM
