Y8 Mini-Me
Old Jul 27, 2005 | 08:28 AM
Timmmaaaay's Avatar
Default Y8 Mini-Me
Yeah, I'm sure most of you are thinking go search the forum's for an article, and I have and recieved a lot of information, but I wanted to get some assurance.
I have a '90 Civic SI Hatch, with the D16A6 and I've read that I will not have the change the distributor, intake, and that the Y8 Head will bolt right up to all these parts. I wanted to be sure that this is true. I've seen all the posts about a Y7/Y8 Swap and then the D15B gone Mini-Me, but not so much with the D16A6 block.
I plan on using a Wiring Conversion Harness to adapt the OBD0 to OBDIIA, so that the P2P ECU will bolt right up, but I'ma bit confused on what wires go where. I was wondering if anyone could help me out here. I heard that there is two wires from the VTEC Solenoid that needs to be connected, there's an O2 Sensor, and there was something else but I cannot remember. If Anyone could get me some help it would be appreciated.
Thanks ya'll.
Peace.
Old Jul 27, 2005 | 09:50 AM
StlSupra's Avatar
Default Re: Y8 Mini-Me (Timmmaaaay)
i don't have an answer but am in the same situation as you and am very interested in what you find out.
Old Jul 27, 2005 | 09:56 AM
djsire's Avatar
im considering this swap also so somone please respond. not to thread jack but does anyone konw how i can wire up my own harness adapter. i figure i would need the male clips off a obd 1 ecu harness, and the sockets off of the d16a6 ecu. ami thinking the right way or???????
Old Jul 27, 2005 | 09:59 AM
djsire's Avatar
Default Re: Y8 Mini-Me (djsire)
ha i just remeberd the vtec is a4 on the ecu run from the green solenoid by the dizzy. and i think the other one is d6 for the oil pressure, which connects to the black connector right next to it. dont foget to ground. this is for obd 1 dont konw if it changed for obd 2
Old Jul 27, 2005 | 10:22 AM
d16vtecx's Avatar
the y8 head will bolt to the a6 block use rour a6 dizz and wiring harness
get an obd0-obd1 conversion harness and an obd1 p28 ecu
Old Jul 27, 2005 | 10:39 AM
Contender25
Guest
Posts: n/a
Here is a pic of one of my old hatchbacks with Y8 head and A6 block. http://server5.theimagehosting...2.jpg
Old Jul 27, 2005 | 10:40 AM
Contender25
Guest
Posts: n/a
Let me know if that link works.
Old Jul 27, 2005 | 12:00 PM
vegaskurt's Avatar
Default Re: (Contender25)
If you go obd1 you cant use the A6 distributor. You will need the obd2 y8 distributor or the obd1 z6 distributor for it to work. The y8 one is a direct bolt on and should work fine on the obd1 p28 ecu.
Hope that helps, I am doing the same but on a d15b2.
Old Jul 27, 2005 | 12:25 PM
StlSupra's Avatar
Default Re: (vegaskurt)
so for a list
basic list
y8 head
y8 gasket
head bolts
p28 ecu
p28 ecu adapter
more advanced list
odb1 dizzy
odb0-odb1 dizzy harness adapter
Modified by StlSupra at 4:01 PM 7/27/2005
Modified by StlSupra at 4:02 PM 7/27/2005
Old Jul 27, 2005 | 12:52 PM
vegaskurt's Avatar
Default Re: (StlSupra)
obd0-0bd1 jumber harness will attach to the p28 and then to your stock harness.
You will need new distributer plugs to match what ever distributer you go with. Rywire sells adapters, or if you can find the clip at a junk yard its easy to splice into them.
Old Jul 27, 2005 | 01:01 PM
StlSupra's Avatar
"obd0-0bd1 jumber harness will attach to the p28 and then to your stock harness."
thats what i meant by p28 adapter
"You will need new distributer plugs to match what ever distributer you go with."
thats what i meant by odb0-odb1 adapter --i'll re-word this one
Old Jul 27, 2005 | 01:12 PM
swifty4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmmaaaay &raquo;</TD></TR><TR><TD CLASS="quote"> I heard that there is two wires from the VTEC Solenoid that needs to be connected, there's an O2 Sensor, and there was something else but I cannot remember. If Anyone could get me some help it would be appreciated.
The two wires should both go to the ECU. Search around for an ECU pinout diagram, and it will show you which pin to run the wires too. Also there is a ground wire from the solenoid that needs to be grounded.
Old Jul 27, 2005 | 09:14 PM
89 crix si's Avatar
hey man, I have an a6/y8 mini-me swap. I replaced the timing belt and headgasket with the OEM y8 ones. i reused the a6 head bolts, im not sure if that was a good idea or not...but i have had no probs yet. I also used the a6 intake mani, header, and dizzy. umm.. i kept it all obd-0 and got someone from dragva.com to chip my pm6 ecu so i could just run 1 wire for vtec. its programmed with the z6 fuel maps, launch control, and a 7200 rev limiter. and to be honest with you, it doesnt really feel that much faster than my a6...but I can definately feel it when vtec kicks in. hope this helps you!
Old Jul 28, 2005 | 02:51 AM
Contender25
Guest
Posts: n/a
Default Re: Y8 Mini-Me (89 crix si)
What he said up above is true. It's only gonna be a little faster, and the best part is you have vtec, if you get the a6 block it's better because it's supposedly the best D series block ever built, havin the Y8 head is like extra cake with the a6 block, it's just perfect. I liked it alot when i had it, and it did run superB.
Old Jul 28, 2005 | 04:24 AM
StlSupra's Avatar
Default Re: Y8 Mini-Me (Contender25)
has anyone ever dyno'd with just i/h/e then dyno'd after a the y8 install
just looking for comparison sheets.
Old Jul 28, 2005 | 04:48 AM
spiceisler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StlSupra &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i meant by odb0-odb1 adapter --i'll re-word this one</TD></TR></TABLE>
Not necessarily so.........I re-used the OBD0 plug from my old dizzy on the OBD1 dizzy. Just repin! The only 2 wires that you can't re-pin is the tach (blue) and the ign (blk/yl) on the 2-pin connector. I just did this like 2-days ago.
Old Jul 28, 2005 | 07:57 AM
driveahonda's Avatar
we just put a vtec pm6 computer in my friends a6/z6, vtec definitely makes power, got the ecu chipped by fabrik8 on dragva.com, hit him up, good to do business with
Old Jul 28, 2005 | 08:42 AM
89 crix si's Avatar
Default Re: (driveahonda)
yep fabrik8 did my ECU too! super nice guy! i have had no problems with his ECU.
Old Jul 28, 2005 | 05:42 PM
Contender25
Guest
Posts: n/a
Suppsedly, some people say the Z6/A6, or Y8/A6 mini me swap, with i/h/e and a cam with some tuning, is quicker then a b16a, and to top it off, it's lighter, was talkin to a bud of mine about this, me and especially him would know, we both had mini me hatchbacks.
Old Jul 28, 2005 | 10:57 PM
89 crix si's Avatar
im not sure about that...all i have is an intake, lol. its decent tho. i dont have any complaints. anyways.....good luck with your swap man, if you have any questions...ill try to help ya!
Old Jul 29, 2005 | 05:01 AM
Contender25
Guest
Posts: n/a
Well all i had was basic intake with some headers, but no exhaust or cam, but the thing ran perfect and was a bit quicker when my buddy got vtec hooked up on it, of course it took forever to warm up though..lol.
Old Jul 29, 2005 | 05:07 AM
beyondspexj's Avatar
most definetly convert to a full obd1 to take full advantage of the swap. other wise its a half *** job that you did for nothing. if you wnat to make it quick with honda parts, find a d15b head and use that or find the cam from the motor. the cam is more aggressive than the stock z6 or y8 and is comparable to a zex cam.
RiTtEk401
Oct 23, 2011 06:12 PM
superhatchbackbros
Sep 30, 2010 05:59 AM
assassinACE12
Oct 24, 2007 01:32 PM
Super Chicken
Mar 7, 2005 06:15 PM
greddytunedhatch
Feb 7, 2005 04:47 PM
