ECU PROBLEMS!!
Old Jul 27, 2005 | 06:47 AM
racerzedge's Avatar
Default ECU PROBLEMS!!
Hey guys, just got a new ecu with a zif socket. Plugged it in but when i turn it on the check light comes on and wont go off, and also there is a resistor that wont let me pass 4,000rpm any ideas to what this could be and how i could resolve it? Car is a 93 honda civic hatch sir2(b16a2) and the ecu is odb1 p28, thanks
Old Jul 27, 2005 | 08:24 AM
drdisco69's Avatar
Default Re: ECU PROBLEMS!! (racerzedge)
Is there a chip in the socket? Make sure it's installed properly, the notch in the end of the chip should point towards the connector side of the ecu. Make sure there are no bent pins, and nothing was screwed up when it was chipped. If everything looks ok, it may be a bad chip.
Old Jul 27, 2005 | 08:32 AM
racerzedge's Avatar
Default Re: ECU PROBLEMS!! (drdisco69)
the connector side being where i plug the wires in right?
Old Jul 27, 2005 | 08:39 AM
drdisco69's Avatar
Yes. With the connectors where you plug the ECU into the car on your left, the notch in the chip should also be facing to the left.
Old Jul 27, 2005 | 08:50 AM
mmuller's Avatar
Mad Scientist
sounds like a bad soldering job
Old Jul 27, 2005 | 08:57 AM
racerzedge's Avatar
think its a bad soldering job too to be honest! just tried it with three different chips and nothing! wont open it to check cos itl ruin the warranty so will just send it back! thanks anyway guys
gshatch
Engine Management and Tuning
10
Mar 20, 2009 05:48 PM
95sloweg
Jan 14, 2008 05:46 PM
ICEMAN707
12
Jul 2, 2006 03:45 PM
bleedblue94
11
Apr 6, 2006 04:07 PM
5STAR3
Mar 20, 2004 04:40 PM
