H22 stock fuel pump capabilites? (searched)
Old Jul 25, 2005 | 12:05 PM
jmac's Avatar
Default H22 stock fuel pump capabilites? (searched)
A buddy of mine is boosting his H22 in his 97 4 door civic today, running a P28 w/uberdata, 550cc injectors, 8psi. His Walbro pump is going to be in tommorrow and we are wondering if the stock pump would be enough to keep up with the setup for a couple of test runs before the walbro is in?
And at what HP point does the stock feul pump definetly have to be replaced?
I've searched but haven't seen much good info.
Old Jul 25, 2005 | 12:22 PM
dennis's Avatar
Default Re: H22 stock fuel pump capabilites? (jmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmac &raquo;</TD></TR><TR><TD CLASS="quote">A buddy of mine is boosting his H22 in his 97 4 door civic today, running a P28 w/uberdata, 550cc injectors, 8psi. His Walbro pump is going to be in tommorrow and we are wondering if the stock pump would be enough to keep up with the setup for a couple of test runs before the walbro is in?
I've searched but haven't seen much good info.</TD></TR></TABLE>
The civic or H22? I've been running with my stock F22 pump which is probably similar to the H22 pump up to 10PSI with no problem. Walbro's going in when I raise max boost though.
If you insist on "test runs", make sure you have a wideband in there to monitor AFR
Old Jul 25, 2005 | 01:19 PM
jmac's Avatar
Default Re: H22 stock fuel pump capabilites? (dennis)
yeah i mean the civic fuel pump. If it can't handle it he going to just wait for the walbro, then it going for dyno tuning.
djnikko
Jan 21, 2010 11:27 AM
. o 69 o .
Feb 20, 2004 08:21 AM
Kp_VtekNiks
Oct 11, 2003 08:48 AM
fastwanabe
Jul 9, 2003 04:03 AM
VTC_CiViC
Nov 9, 2001 06:09 AM
