Help headlights get brighter when i gas car!
Old Jul 24, 2005 | 10:07 PM
ej6g's Avatar
Default Help headlights get brighter when i gas car!
As said above only when i gas it lights get brighter then i let off it gets a lil dimmer anybody know what can cause this?
Old Jul 24, 2005 | 10:08 PM
97exd16's Avatar
Default Re: Help headlights get brighter when i gas car! (ej6g)
crappy alternator
Old Jul 24, 2005 | 10:13 PM
ej6g's Avatar
Default Re: Help headlights get brighter when i gas car! (97exd16)
if it is a crap alterneter am i losing power from my engine?
Old Jul 24, 2005 | 10:25 PM
97exd16's Avatar
your alternator is weak its not working properly and there fore its not supplying the power to make the bulbs bright as when you gas it when you gas it then it spins faster and more power is made
Old Jul 24, 2005 | 11:25 PM
96CivicBoostCoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97exd16 &raquo;</TD></TR><TR><TD CLASS="quote">crappy alternator</TD></TR></TABLE>
check your Ground points, especially the underhood fuse box
Old Jul 24, 2005 | 11:51 PM
Traymack1's Avatar
maybe you have aftermarket pulleys
Old Jul 25, 2005 | 04:04 AM
JDM-EJ1's Avatar
Weak alternator.
Old Jul 25, 2005 | 08:54 AM
chinkest_raver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6g &raquo;</TD></TR><TR><TD CLASS="quote">As said above only when i gas it lights get brighter then i let off it gets a lil dimmer anybody know what can cause this?</TD></TR></TABLE>
might be ur battery too..change it too! not that much, and cost less than the alt....how much miles are on the car??
Old Jul 25, 2005 | 10:45 AM
Agoraphobic Nosebleed's Avatar
If it not a major change in the brightness, don't worry about it. It is pretty normal. With alot of the cars I've owned, I've noticed the headlights dim a tiny bit at idle.
If its a big difference, then check your grounds, alternator, and consider possibly replacing the battery as well, if its old.
Old Jul 25, 2005 | 10:53 AM
Relic1's Avatar
Default Re: Help headlights get brighter when i gas car! (Apologetic Theory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apologetic Theory &raquo;</TD></TR><TR><TD CLASS="quote">If it not a major change in the brightness, don't worry about it. It is pretty normal. With alot of the cars I've owned, I've noticed the headlights dim a tiny bit at idle.
If its a big difference, then check your grounds, alternator, and consider possibly replacing the battery as well, if its old.</TD></TR></TABLE>
what he said.
things that will cause the lights dim at idle.
ground wires
battery - especially if it cranks a little slower
alternator - doubtful it's totally bad though if the lights brighten up when you accelerate.
check in that order.
Old Jul 25, 2005 | 10:56 AM
JDM-EJ1's Avatar
Ground wires could definitely effect it, as well as bad battery. Alternator is the big thing though, check all the small easy stuff first, and then check the alternator.
Old Jul 25, 2005 | 11:02 AM
jadugartir's Avatar
Default Re: Help headlights get brighter when i gas car! (JDM-EJ1)
if your alternator is bad, then you have worse things to worry about than if your engine is losing power, like "will my car start the next time i turn the key?"
Old Jul 25, 2005 | 11:47 AM
distortedfuture's Avatar
Old Jul 25, 2005 | 12:14 PM
Nyceguy17's Avatar
Default Re: Help headlights get brighter when i gas car! (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Ground wires could definitely effect it, as well as bad battery. Alternator is the big thing though, check all the small easy stuff first, and then check the alternator.</TD></TR></TABLE>
Old Jul 25, 2005 | 09:24 PM
ej6g's Avatar
Default Re: Help headlights get brighter when i gas car! (Nyceguy17)
thanx guys imma check all my grounds.i had the alternater checked by a repair shop they said it was all good.also it dims jus a lil bit but nothin major.
Old Jul 25, 2005 | 09:26 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6g &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys imma check all my grounds.i had the alternater checked by a repair shop they said it was all good.also it dims jus a lil bit but nothin major. </TD></TR></TABLE>
Awesome, if it's not the alternator. It's definitely bad grounds, check all your grounds, if they're faulty, replace them.
vlc92189
10
Sep 24, 2007 08:20 PM
RIPPO
Nov 29, 2005 04:38 AM
mr0lg
Aug 28, 2005 10:08 PM
Phatch99
Jul 22, 2004 01:37 PM
GRAVEDIGGER
22
Oct 11, 2003 11:15 PM
