brake swap
Whats up fellow honda-techers I was wondering if someone could give me a parts list for everything I need to do the GSR to Civic brake conversion I need the parts for the front and rear so I know exactly what to get this weekend at the junkyard.I've tried to search but I couldnt find exactly what I needed so any help would be great thanx
Didn't search hard enough. E-brake cables, and the whole brake assembly (Spindles etc) to be safe. I am not sure if the e-brake cables are the same or not. The rear trailing arms are the same (if you are talking about '94-00 Teg and '96-00 Civic), as the Teg ones on my car were bent and I was able to use the Civic ones.
-Shane
P.S. New prop valve and m/c is good according to most people, although I still have the Civic ones and it is still way better.
-Shane
https://honda-tech.com/zerothread?id=1069787
Just in case you would like to look. There were 109 theads under my search. I think it was rear disc swap, but not sure. ebeer Sunday!
-Shane
-Shane
Cap'N Chronic
Mar 27, 2022 07:16 AM
mikey1992
May 9, 2010 07:35 AM
