Saturated injector wiring question
Old Jul 23, 2005 | 09:21 PM
2phast's Avatar
Default Saturated injector wiring question
I currently have a resitor box wired in to low impedence 1000 cc injectors.
I am switching to 750 cc Saturated injectors.
Is it as simple as taking the 5 (one input power source and four injector wires) that go into the resistor and connecting them all together with a terminal block?
Thanks for any help you all can offer.
Ralph
Old Jul 24, 2005 | 06:28 AM
mdixonjam's Avatar
Default Re: Saturated injector wiring question (2phast)
Are you upgrading your ECU as well or are you just trying to upgrade the injectors only?
I know if you convert from OBD0 to OBD1 you can simply join all 5 wires together and change the injector plugs to the newer OBD1 plugs.
See the following link for a cleaner way to convert your injectors:
http://www.rywire.com/repininj.shtml
What I don't know is if the OBD0 ECU supports saturated injectors any at all.
You should verify this before proceeding, if this is what you are trying to do.
Old Jul 24, 2005 | 09:09 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2phast &raquo;</TD></TR><TR><TD CLASS="quote">Is it as simple as taking the 5 (one input power source and four injector wires) that go into the resistor and connecting them all together with a terminal block?
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdixonjam &raquo;</TD></TR><TR><TD CLASS="quote">See the following link for a cleaner way to convert your injectors:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdixonjam &raquo;</TD></TR><TR><TD CLASS="quote">What I don't know is if the OBD0 ECU supports saturated injectors any at all.
The ecu doesn't care what type of injectors you use.
saturated=no resistor box
p&h=requires resistor box
It's that simple.
Old Jul 25, 2005 | 06:18 AM
2phast's Avatar
Default Re: Saturated injector wiring question (eda6)
Thanks for the answer I needed.
I have already upgraded from OBD0 to OBD1.
The 92-95 Civic Wiring diagram shows a terminal block.
Maybe I can come up with a way to make it easy to switch back and
forth. I think I will try to find a 6 wire plug to make a terminal plug
that can be removed if I ever want to go back to the resistor box.
Thanks again all for the help
Ralph
RICE POLICE SIP
Feb 13, 2010 10:01 AM
AmauryR
Nov 15, 2007 09:46 AM
erikespo
May 1, 2005 07:19 AM
civicefdx
Oct 18, 2004 04:38 PM
URNVS
Aug 18, 2004 02:21 PM
