PR3 injector question
Old Aug 16, 2004 | 10:37 PM
URNVS's Avatar
Default PR3 injector question
I have a B16 swapped into a CRX Si with a PR3 ECU and have a couple of questions. From what I understand the injectors are peak/hold 240cc. I happen to have a set of saturated 550cc injectors here and am thinking about swappiung them out. Am I correct that the PR3 ECU will run saturated injectors if I remove the CRX resistor pack and solder the wires together? Also, what kind of fuel management is needed/recommended when going to 550cc injectors?
Old Aug 17, 2004 | 10:28 AM
URNVS's Avatar
Default Re: PR3 injector question (URNVS)
Anyone?
Old Aug 17, 2004 | 10:30 AM
Malgerus's Avatar
Too big, kinda useless.
But you can run them by removing the injector resistor box located on the driver's side firewall area. There's a power in wire, which splits off into 4 wires for each peak and hold injector. If you remove the injector resistor, just splice these all together into the main power wire.
Don't even think about running these without management.
Not really worth it IMO, unless you're boosting.
Old Aug 17, 2004 | 01:45 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: PR3 injector question (Mr. S)
If you want some bigger injectors without all the trouble, get some OBD1 (310-345CC) Peak and Hold injectors.
Old Aug 18, 2004 | 02:21 PM
URNVS's Avatar
Thanks for the info! The reason I want such big injectors is because I am going turbo down the road but I think I have a leaky injector right now but do not want to have to buy a set to use for just a short while. Any suggestions for management?
siguy2k
Aug 19, 2012 09:20 AM
efjones9
May 9, 2009 03:10 PM
dave24
Aug 3, 2006 07:43 PM
UncleBen'sRacing
May 20, 2003 03:17 AM
satan_srv
Nov 15, 2002 06:12 AM
