re-tuned with hondata200 - boost
Old Jul 22, 2005 | 09:50 AM
boosted_LS's Avatar
Default re-tuned with hondata200 - boost
hey i just got my car re-tuned with a hondata now compared to vafc2 . im happy even tho it cost alot im happy with the results. im pushing 223whp@7psi on a stock ls. but at the dyno they had told me when i push on the pedal down 100% a check light shows up.. but it can be gone if i just turn the car offf and turn it back on. they told me it might be my throttle body. what kind of throttle body should i get?
Old Jul 22, 2005 | 09:54 AM
tik_tok's Avatar
Default Re: re-tuned with hondata200 - boost (boosted_LS)
i would like to know what all done you ahve to your ls, becuase i want to have a siiliar setup, also my top end is being built , so with my top end , skunk 2anifold , what kind of numbers should i be putting out, i hope to be bossting that why i am building the motor, but yours is stock so i wanted to see how thats going,
Old Jul 22, 2005 | 09:59 AM
boosted_LS's Avatar
t3/t04 turbo tial wastegate turnetic manuel boost controler . msd 2 step . 3 in downpipe with 3 inch exhaust hondata tuned aem fuel rail custom turbo manifold hks ssq bov spearco fmic chipped ecu and other lil things
Old Jul 22, 2005 | 01:28 PM
acuragtr's Avatar
I'm pretty sure getting a new throttle body wont change the check engine light from coming on. More then likely you need a 3 bar map sensor, or somthing along those line. R you using missing link, or check vuals?
Old Jul 22, 2005 | 03:48 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_LS &raquo;</TD></TR><TR><TD CLASS="quote">hey i just got my car re-tuned with a hondata now compared to vafc2 . im happy even tho it cost alot im happy with the results. im pushing 223whp@7psi on a stock ls. but at the dyno they had told me when i push on the pedal down 100% a check light shows up.. but it can be gone if i just turn the car offf and turn it back on. they told me it might be my throttle body. what kind of throttle body should i get? </TD></TR></TABLE>
Did they tell you what code your vehicle was throwing.
If all they told you was you have a check engine light throwing at 100% throttle. You need to find a better hondata tuner that has a clue as to what they are doing.
Old Jul 24, 2005 | 01:58 PM
boosted_LS's Avatar
midnight performance if u guys know of them. there in sac and there pretty known and good at tuning hondata's.. the wire that the pedal is hooked up to. he tighten it up so its not that loose . it prevents it from throwing the light. but i had told him i dont like it cause the pedal feels wierd so he made it loose and he told me when i full throttle it it will come on but it will come off after you turn off n return on the car.
Old Jul 24, 2005 | 04:37 PM
papito's Avatar
Tune your motor je throttle bdoy
I'm selling fully built motor for 1100
turbo90accord
Feb 13, 2011 09:01 AM
gosu08
Oct 17, 2009 09:52 PM
Rikter
May 4, 2006 08:15 AM
Aeka GSR
May 22, 2002 11:16 PM
bgod
Jul 26, 2001 05:45 AM
