$15 Ebay Short Shift System vs. B&M/Skunk2 $100 Short Shifter System
yes there is a very big difference, ebay peices of **** break over time which= bad. Skunk2 and b&m dont break that is what the are marketed for. and B&m has a life time warranty with there short shifters.
Also, the measurements on a short shifter are very exact. A piece of junk like something on Ebay could possibly throw off the geometry of your linkage, leading to transmission damage.
I had an ebay cheapie, it was loose and rattled alarmingly at high RPM's. I got a new B&M steel shifter with pivot assembly now. It fits much better, and has bushings that actually fit, instead of the POS shim washers that the ebay special came with. I would avoid the cheap ones, just stick with stock or buy a good one.
my cousin gave me a short shifter that he bought off of ebay. It's broken in half now. i guess i shifted too hard lol. dont buy cheap **** cuz its made out of cheap ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wolfwood »</TD></TR><TR><TD CLASS="quote">Both aluminum, let's say. Is there a big difference?</TD></TR></TABLE>
The B&M and the Skunk 2 shifters are NOT aluminum, they are steel. Steel gives you a nice feel because of the weight. The best shifter (I don't know if they are still around) is the Pacesetter steel short shifter. It is adjustable with a threaded delrin shifter ball and a setscrew to hold it in position. You can have it as short as you want or longer than stock. I have had mine since 1998 and it still works great.
Simple
Aug 21, 2005 11:28 PM
