shimming oil pump fpr higher pressures
Old Jul 21, 2005 | 07:42 PM
daveedd357's Avatar
Default shimming oil pump for higher pressures
has anyone done this before and how? I have an 99 accord engine
Old Jul 22, 2005 | 02:31 AM
rainforest's Avatar
Default Re: shimming oil pump for higher pressures (daveedd357)
i would hate to be a jerk but next time try a search. you add a shim (washer) between the screw on the bottom of the pump and the relife spring. The washer will be between the spring and the bolt putting tension on the spring. Making it take more pressure to open the valve
Modified by rainforest at 11:08 PM 5/4/2006
Old Jul 23, 2005 | 08:51 AM
mmuller's Avatar
Mad Scientist
why would you want to do this? are you loosing pressure anywhere?
JDMCRX
Feb 19, 2008 03:43 AM
gawath
Dec 23, 2005 05:40 PM
PURPLETERROR aka BIGMATT
Jun 21, 2005 03:49 PM
H22Si
Nov 27, 2004 09:29 AM
-KangaRod-
Mar 22, 2004 02:52 PM
