dx rpm question
Old Jul 20, 2005 | 10:21 PM
legron_m's Avatar
Default dx rpm question
would the stock internals on the 1.5 sohc be able to handle 8000 rpm on a daily driver?
Old Jul 20, 2005 | 10:26 PM
Fulthrotle's Avatar
Default Re: dx rpm question (legron_m)
What are you running external? ie: turbo/sc and is the bottom end and the head stock?
Old Jul 20, 2005 | 10:28 PM
mike93eh
Guest
Posts: n/a
a stock dx head stops making power at around 5500-6000 rpms. so why would you want to rev it that high? and you would hit the rev limter.
legron_m's Avatar
Default Re: dx rpm question (Fulthrotle)
all his car has done is like i/h/e
Old Jul 20, 2005 | 11:03 PM
FalkenSiR's Avatar
I/H/E ain't sh#t man. IF you had no rev limiter you would tell as you go higher and higher in the rpm range that after a certain rpm, the motor is working itself out and not making any power at all. It happened in my pos sohc 1.5 (EF motor).
If you want to blow that motor up real quick then yea go ahead.
Old Jul 21, 2005 | 09:53 AM
legron_m's Avatar
Default Re: dx rpm question (fast88std)
allright guys thanks for your help!!!
Old Jul 21, 2005 | 10:17 AM
Otherguy's Avatar
NASIOC.com
i was using nos with no rev.... oh snap 8000 grand came and went hit 9000 and dropped a valve...
Old Jul 21, 2005 | 11:39 AM
douspray's Avatar
Default Re: dx rpm question (Otherguy)
the stock valve springs will give up at 8k.
arren123
19
Jul 30, 2019 04:09 AM
thedirty-Dseries
Apr 18, 2006 07:16 PM
hondacivic4g
Apr 20, 2004 07:36 AM
GapxGuy
Aug 4, 2002 09:15 AM
ion_four
Jun 28, 2002 10:55 AM
