looking for a safe rev limit
How high do you think I could rev, on a regular basis ,a D16Y7 (99 DX) sohc nonvtec head w/ stock valve train?It's on a D15B2 block. My buddy used to run his D16Y7 head to 9000-9500 rpm all the time. I figured 8000-8200 would be ok, but I figured I'd let others who have experience or knowledge give me there input.This is an all-motor project.My mods are listed in my signature. Head has a street/strip cam and i'm running for now a PG-7 89 teg ecu.
Thanks-Jason
Modified by hondacivic4g at 12:03 AM 4/19/2004
Thanks-Jason
7000 max (Safely)
No way should you be winging a sohc up to 8000+ without some nice headwork and upgraded valvetrain. As for your friend that goes 9000+ - that's insanity. Takes quite a bit for a B16 to go that high safely and the B16 is made to rev.
stock sounds about right. if you completed your vavletrain with springs/retainers, it would go up a little, and if you had the bottom end balanced, it would go up more again
yeah, stock for now....since you dont have a upgraded valvetrain. Contact crower to see what they say about the cam's powerband and go from there, depending on what they tell you red line should be.
arren123
19
Jul 30, 2019 04:09 AM
