RC injectors SL2-310
it all depends what ECU your running.......if its OBD1 or 2 then no you will not need a resistor box. if you have a OBD0 then you probably will depending on what ECU you have.
i see. what car were they on? what my goal is that i am currently using DSM 440cc with inline resistors. would I then have to remove them to use the RC injectors?
at about 5.5psi, apparntly these injectors are maxing out. im goin to scan the dyno chart tomorrow. but the A/F from 3k-5k rpms, with the safc2 at 0 correction, runs between 14-15. its puttin down 136/137 fwhp/tq. ideas ?
the 310's. i swapped them out for a set of 440's. its running smoother. dyno opens tomrow so i have a good feeling that the results will be better and at boost, i wanna be at 12ish A/F
