Oil feed line AN/NPT connectors question
Old Feb 18, 2002 | 12:13 AM
Xerxes's Avatar
New User
Default Oil feed line AN/NPT connectors question
I picked up some -3 hose and -3 to 1/8" Aeroquip fittings last week and today I was trying to put everything together. I took apart the brass T's etc that were all on my block and started to reassemble things but it seemed like the Aeroquip fittings didn't want to thread in very easily.
The original parts were all 1/8" tapered threads but the new Aeroquip parts seem to be straight 1/8". I can only turn them two full rotations before they get tight. Is this okay? I plan to use plenty of teflon I can post a pic if someone wants, here's just the part by itself:
Also, do i need teflon on the connection between the stainless line and that fitting? I was going to put some on there but the importparts.com instructions say not to???
-Xerxes
Old Feb 18, 2002 | 05:56 AM
G's Avatar
G
Default Re: Oil feed line AN/NPT connectors question (Xerxes)
Some 1/8"npt threads are actually cut bigger than some FPTs. I encounter this all the time with brass fittings. Maybe go to the home depot and test fit your fitting on some FPT nipples and stuff. A tapered thread will almost always stop when there is still thread left (visible). A straight cut thread will go all the way until the bottom of the fitting binds it. I don't reccomend too much tef tape, 2 good passes should suffice. Does the fitting stop so early if you thread it in without teflon?
Don't use teflon on the flare/AN side....
Old Feb 18, 2002 | 06:19 PM
GruvyTune's Avatar
New User
my earls fittings 1/8npt also don't thread very far in my 1/8 T.
the AN threads go in just fine. I use liquid teflon on the pipe thread and have no leaks at all. The AN fittings don't need a thread sealant since they are a compression fitting.
Old Feb 26, 2002 | 03:04 PM
Xerxes's Avatar
New User
Default Re: Oil feed line AN/NPT connectors question (GruvyTune)
thanks for the responses
okay now i have a 1/8" NPT female/female adapter (earl's) that i just picked up; my aeroquip AN/NPT adapter will only thread into that about 1.5 turns before it starts getting tight (this is with no teflon). Will this be strong enough or should i try to find a tapered AN/NPT adapter?
I wonder if they'll let me get a refund
-Xerxes
Old Feb 26, 2002 | 03:07 PM
dustin's Avatar
NPT is always tapered... but I find that some are just larger than others....
Old Feb 26, 2002 | 11:42 PM
Xerxes's Avatar
New User
Default Re: Oil feed line AN/NPT connectors question (dustin)
Yeah that's what i thought, but i swear that the fittings i have look straight as an arrow. Oh well, i'm gonna go ahead and use them (with that greddy oil filter adapter block i've got) and if it leaks then i'll worry about it later
-Xerxes
Old Feb 27, 2002 | 05:17 PM
1fstevo's Avatar
New User
It's BSP on the greddy sandwich.
hondatuner020
Apr 26, 2011 05:26 PM
philafelman
Nov 4, 2009 06:21 PM
gooberguy31
Feb 25, 2009 12:09 PM
Black R
Feb 20, 2005 03:12 PM
beepy
Mar 1, 2004 09:26 PM
