IAT Wiring Question for gsr swap
Old Jul 19, 2005 | 04:36 PM
EgSalad's Avatar
Default IAT Wiring Question for gsr swap
So i just put a GSR motor in my eh3, and everything is done, except the IAT (Intake Air Temp) sensor isnt plugged in.
So heres my situation..
Right now ive got a stock GSR intake manifold on the motor, so I can pass the visual for smog (BAR ref). Ive you've done the swap, you know that the civic wiring for the IAT sensor wont reach the IAT on a GSR manifold. Its about 6-8" short. Ive pulled and pulled and tried to move the harness around under the manifold so it will reach.. not no go.
I didnt really wanna f#ck with my harness and do any soldering or whatever.. because as soon as I pass smog, I have a S2 manifold im putting on, and the stock harness would work fine.
So, is there an easy way to do this, or should I just be over it and solder in an extension for the time being and change it again when Im done with smog?
TIA.
Old Jul 19, 2005 | 06:52 PM
SkRiBLaH's Avatar
Default Re: IAT Wiring Question for gsr swap (EgSalad)
sounds like you'll just have to cut and solder, and tape it up OEM style. and just rock it with some slack when you put the s2 manifold on.
ek.troy
Aug 8, 2011 04:24 PM
guy_from_nerk
Jan 23, 2010 07:50 PM
Achenar
24
Dec 1, 2004 05:14 PM
Wes V
Jan 9, 2003 07:16 AM
