Anyone ever try dynoing there vtec engine without these two parts? oring dowel pin
hey guys
http://www.hondaautomotivepart...EC%29
has anyone ever tried dnyoing there car without part numbers 23 and 24 and relizing that vtec sounds like its engaging but its not making any power?
1991 honda crx si
b16a
j1 tranny
pr3 ecu
hondata wiring
sport compact sci
450cc injectors
walbro255
t3/t4e 63.48ar
tial wastegate
fmic
9:1 compression pistons .020 overbore
scat rods
acl bearings
honda headgasket
arp main and head studs
stock dizzy
new plugs
msd 8.5mm spark plug wires
ctr crank pulley
10k timing belt.
stock fuel rail.
i made 200whp at 4200 rpm, and then it just dies off. i think im missing these two parts. anyone else have this problem? would htis be why my vtec isint making any power?
1991 honda crx si
b16a
j1 tranny
pr3 ecu
hondata wiring
sport compact sci
450cc injectors
walbro255
t3/t4e 63.48ar
tial wastegate
fmic
scat rods
acl bearings
honda headgasket
stock dizzy
new plugs
ctr crank pulley
10k timing belt.
stock fuel rail.
I forgot same ****, had to pull head off.
I have "heard" that you can ruin your cam journals cause of lack of oil cause this dowel pin provides oil to the top of the cam caps.
otherwise, oil is most likely spraying out from under the cam cap since these are not there.
Search on my name for post all about this.
Dylan_boosted95
Engine Management and Tuning
16
Apr 7, 2018 05:06 AM
onegreedy
Jan 4, 2006 02:58 PM
NotPhilTran
Jul 4, 2005 06:37 AM
