check compression
Old Jul 18, 2005 | 11:44 PM
eg6T's Avatar
Default check compression
is there a way to check compression with the motor out of the car? my motor is on a stand and would like to know if i can check the compression.thanks
Old Jul 19, 2005 | 05:37 AM
Lewdin' Incognito's Avatar
Default Re: check compression (eg6T)
I don't see why not....use the crankshaft nut just like you do when you're turning it over to set timing. It will take a while, but shouldn't be a problem.
Old Jul 19, 2005 | 08:38 AM
MatHadder's Avatar
I have used the starter to check compression on a motor that is out of the car. Just hook it up to a battery. make sure there is plenty of oil in the engine, and it should at least give you a decent idea of the compression, although the compression is going to be different when the engine is warmed up.
Old Jul 19, 2005 | 08:50 AM
BoostdRex's Avatar
Default Re: check compression (MatHadder)
It's hard to use the starter if it's on an engine stand (usually no tranny to mount the starter on).
Old Jul 19, 2005 | 10:56 AM
eg6T's Avatar
Default Re: check compression (BoostdRex)
thanks for the replies guys
Old Jul 20, 2005 | 04:03 PM
MatHadder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostdRex &raquo;</TD></TR><TR><TD CLASS="quote">It's hard to use the starter if it's on an engine stand (usually no tranny to mount the starter on).</TD></TR></TABLE>
Yeah, i guess that is a good point. I did it on a motorcycle engine with an integrated transmission, so it wasnt a problem.
JDM_EK_JOE
Oct 22, 2007 07:11 PM
SL_RICK83
Jun 17, 2006 12:49 PM
insomniac791
Sep 19, 2005 12:36 PM
Propulsion
Feb 14, 2003 11:11 AM
4potnick
Jul 23, 2002 04:24 PM
