idle ??
Fast idle valve is indeed beneath the throttle body for one thing but I doubt that's the problem. Second a vacuum leak isn't likely to make your idle bounce between 1000+2000 rpms. Vacuum leaks usually raise the idle period. I'd check voltage on the tps and check your idle air control valve!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">sounds like a vaccum leak. check to make sure all ur vaccum hoses are on. make sure everythign connected to the intake manifold is tight.</TD></TR></TABLE>
Sounds like a vaccum leak.
IntegraType-R
11
Jan 20, 2008 11:23 PM
4gen
Jan 11, 2004 05:28 PM
