hestiation/bogging problems - 92 CX w/ D16Z6 motor
Old Jul 17, 2005 | 12:36 PM
SDT Project EF's Avatar
Default hestiation/bogging problems - 92 CX w/ D16Z6 motor
I got a 92 civic CX with a Z6 swap. im still running the PO5 ecu in the car and the car doesnt wanna run too well. itll idle but once you open the throttle itll hesitate and bog down. youll hear a surge of air and the motor will bog down lower in RPM.
i put in a P28. nothing same thinmg
checked the TPS and swapped that out and put a diffrent TPS in .45 at idle its 4.62V at WOT.
compression test. 208-208-210-208 PERFECT.
firing order =-
no CEL either.
im stumped. everything is in order and seems perfect. anyone got any ideas ?>
motor has an AEM cam gear. and its also TDC.
Old Jul 18, 2005 | 12:08 AM
project dc2's Avatar
Default Re: hestiation/bogging problems - 92 CX w/ D16Z6 motor (SDT Project EF)
ttt for a buddy
mattmanz71
Nov 2, 2010 08:19 PM
JESSE775
Sep 24, 2010 04:32 PM
LudeJdm
Mar 9, 2006 05:18 PM
neocrynym
15
Jul 30, 2004 09:11 PM
1meangsr
Feb 17, 2004 06:20 PM
