92 civic cx starts but then dies
have a stock 92 civic cx it starts but 3 min after it shuts off..I have tryed a working main relay and dizzy and changed a new fuel filter still does the same thing......what could it be HEELLPPPPP PLLLEEAAASSEEE!!! thanks
Re: 92 civic cx starts but then dies
no cel codes starts fine but after 3-4 min it dies and takes a lil while to start up again....so i cant drive it cause it dies..............
It sounds like you're only idling during fast idle, which leads me to believe that you aren't getting enough air during normal idle. Check/clean your idle valves and TB. Properly set the idle, preferably using a shop manual. If you are unable to fix the problem with the above suggestions, try a compression test.
kanjozoku
26
10-02-2016 03:14 PM
ntensehonda
10
01-14-2004 10:15 AM
