3 to 2 iacv wire help??
Old Jul 17, 2005 | 02:44 AM
hifi_civic's Avatar
Default 3 to 2 iacv wire help??
i need to switch the auto 3 wire iacv to a manual 2 wire iacv. anyone know how i do that?
all help is greatly appreciatted.
thanks
Old Aug 3, 2005 | 07:23 PM
ek9vboi2's Avatar
if u still need to know the orange wire is nothing. just cut it or pull the pin.
Old Aug 3, 2005 | 07:36 PM
perlmeister8's Avatar
Default Re: (ek9vboi2)
http://www.ff-squad.com/tech/w...8.jpg
Old Aug 3, 2005 | 07:42 PM
Civic4less's Avatar
Default Re: (perlmeistere81)
ARE YOU SERIOUS!?!? So I don't have to change my IM to a 5-spd version??
Old Aug 3, 2005 | 07:57 PM
ek9vboi2's Avatar
Default Re: (Civic4less)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less &raquo;</TD></TR><TR><TD CLASS="quote">ARE YOU SERIOUS!?!? So I don't have to change my IM to a 5-spd version??</TD></TR></TABLE>
nope, not at all.
i remember reading about it and the orange wire is like a ground wire, saw it in the helms manual.
i drove around like that for a while, but got a skunk2 for my lil d16y8.
Old Aug 4, 2005 | 04:54 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">if u still need to know the orange wire is nothing. just cut it or pull the pin.</TD></TR></TABLE>
What he is referring to is when you've already completed the 3 to 2-wire swap. At that point, the orange wire has no function. It can be pulled from the ECU connector if you wanted to since it is NOW connected to nothing.
But if you thought you could control a 3-wire IACV with an ECU that originally controlled a 2-wire IACV, think again.
Old Aug 4, 2005 | 05:10 AM
mc's Avatar
mc
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">But if you thought you could control a 3-wire IACV with an ECU that originally controlled a 2-wire IACV, think again.</TD></TR></TABLE>
damn I had my hopes up for a minute
Old Aug 4, 2005 | 12:37 PM
Civic4less's Avatar
Default Re: (mc)
Ok so. Say I get the 5-spd ECU for the HX. And use that instead. And change hte 3-wire over to 2-wire. It should work right? (Assuming I repin it correctly)
Old Aug 4, 2005 | 12:53 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less &raquo;</TD></TR><TR><TD CLASS="quote">Say I get the 5-spd ECU for the HX.</TD></TR></TABLE>
Are you trying to source an Hx ECU or you have an Hx that is currently auto? The only 6th gen Civic ECUs that control a 2-wire IACV are the D16Y5, Y8 and B16A2 with manual tranny.
So the answer: Yes. If you get one of the above ECUs, a 2-wire IACV, swap the connector and do the pin swap, it'll work....assuming you re-pin it correctly.
Old Aug 4, 2005 | 01:02 PM
Civic4less's Avatar
Yea I already have an AUTO HX... and I'm gonna be doing a 5-spd swap soon. So thanks for the quick response!
Old Aug 4, 2005 | 01:07 PM
ntrider's Avatar
check my sig., the only website so far. It is a link to a detailed write-up of a mini-me swap. About 2/3rds down talks about the IACV and how to re-wire a 3 wire to a 2 wire. Good Luck
Old Aug 4, 2005 | 01:46 PM
99hatch's Avatar
Default Re: (ntrider)
so it sounds like you can still use the 3 wire connector when trying to connect it to the 2 wire plug on the manifold? am i wrong?
Old Aug 4, 2005 | 02:01 PM
EE_Chris's Avatar
Default Re: (99hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch &raquo;</TD></TR><TR><TD CLASS="quote">am i wrong?</TD></TR></TABLE>
Yes.
In addition to moving a wire at the ECU connector, you must also swap the connector that plugs into the IACV from a 3 to a 2 wire style.
Old Aug 4, 2005 | 08:17 PM
99hatch's Avatar
you couldnt do like he said and just use wires?
Old Aug 5, 2005 | 03:53 AM
EE_Chris's Avatar
I don't know what you mean by that.....'use wires'??
You chop off the previous 3-wire connector (in the engine bay) and solder on the 2-wire connector. You're now done in the engine bay.
In the cabin, you disconnect one of the ECU connectors and move a wire into a different location. You're now done in the cabin.
Old Aug 5, 2005 | 04:36 AM
fishnfst's Avatar
Listen to Chris he knows what he's talking about... He walked me through mine a couple of years ago....
Old Aug 5, 2005 | 08:13 AM
99hatch's Avatar
Default Re: (fishnfst)
where did everyone get their two wire connectors?
Old Aug 5, 2005 | 09:40 AM
Civic4less's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch &raquo;</TD></TR><TR><TD CLASS="quote">where did everyone get their two wire connectors?</TD></TR></TABLE>
You can get one like at a junkyard or something. Or maybe someone is selling them here on the classifieds.
Or you know what? Go to one of your friends... ask him to pop the hood to his engine bay... Snip off his 2-wire connecter, pocket it, and go home and put it on your car.
It's not an aftermarket peice if thats what you were wondering.
Old Aug 5, 2005 | 09:43 AM
B--RYAN's Avatar
egrunner
Jul 2, 2015 07:57 AM
projektvtec
Oct 3, 2005 09:04 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
mikecivichb
Audio / Security / Video
Apr 4, 2004 10:05 AM
T25 civic
Oct 6, 2002 02:11 PM
