Turbo Question?
Old Jul 17, 2005 | 12:34 AM
Ape's Avatar
Ape
Default Turbo Question?
Do you think that this trubo would be ok for a Stock D16z6? probly boostin no higher then 10 psi. The .48 seems like it would be good for nice spool time but im not sure how the .70 trim is going to affect it.
http://shop.store.yahoo.com/ch....html
I have a T25 .48/.48 but I am having problems with the oil return. Plus I am thinking that it mite be a little on the small side.
Old Jul 17, 2005 | 12:44 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Turbo Question? (Ape)
thats a t3,60-1.... way too big for a stock d-series, even with the .48 turbine housing.
what are your power goals? a 50 trim t3.t04e would be just right for you. stage 3 turbine wheel with a .48 turbine housing.
and that .70 isnt trim, its the compressor a/r. a 60-1 compressor side supports over 600crank hp. too big
Old Jul 17, 2005 | 12:48 AM
Ape's Avatar
Ape
Default Re: Turbo Question? (wantboost)
Power Goals 200hp ish. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote"> a 50 trim t3.t04e would be just right for you. stage 3 turbine wheel with a .48 turbine housing.
Know of a place i can find one of those?
Old Jul 17, 2005 | 09:29 AM
*Boostwerks*'s Avatar
ARTURBO
Ask for an SC50 with the .48 turbine
Old Jul 17, 2005 | 09:31 AM
SOHC_MShue's Avatar
Default Re: (Bryson)
For 200hp that T25 will do just fine.
Old Jul 17, 2005 | 10:08 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ape &raquo;</TD></TR><TR><TD CLASS="quote">Power Goals 200hp ish.
Know of a place i can find one of those?</TD></TR></TABLE>
Why would you want a 630 WHP capable turbo for a 200 HP setup?
Old Jul 17, 2005 | 02:46 PM
Ape's Avatar
Ape
Default Re: (SOHC_MShue)
The thing is im not going to keep the T25. So I need a new Turbo. I would like to get a T3 so i can upgrade the trubo later and still use the same mani when i have my other motor built.
Old Jul 17, 2005 | 02:49 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Ape)
well, what all are you doing to the motor, how high are you going to turn it? once built what are your power goals? i can pretty much help you pick a good turbo if i have all this info and if icant help i can direct you to someone who can
Old Jul 17, 2005 | 05:56 PM
Sille98's Avatar
Default Re: (wantboost)
I got a fresh rebuilt T3 for sale if your interested...
https://honda-tech.com/zerothread?id=1310078
Old Jul 17, 2005 | 08:11 PM
a1320addict's Avatar
Default Re: (Sille98)
have a gt28r for sale...would be awesome on a dseries...https://honda-tech.com/zerothread?id=1311487
Tippyman
Feb 28, 2007 07:46 AM
CarbonCreations
Oct 19, 2005 03:38 PM
tgreaves
Sep 16, 2004 11:28 AM
igotyofire
May 13, 2003 11:12 AM
808eg6
Mar 12, 2002 01:19 PM
