Turbo Question?
Do you think that this trubo would be ok for a Stock D16z6? probly boostin no higher then 10 psi. The .48 seems like it would be good for nice spool time but im not sure how the .70 trim is going to affect it.
http://shop.store.yahoo.com/ch....html
I have a T25 .48/.48 but I am having problems with the oil return. Plus I am thinking that it mite be a little on the small side.
Who is Mr Robot?
thats a t3,60-1.... way too big for a stock d-series, even with the .48 turbine housing.
what are your power goals? a 50 trim t3.t04e would be just right for you. stage 3 turbine wheel with a .48 turbine housing.
and that .70 isnt trim, its the compressor a/r. a 60-1 compressor side supports over 600crank hp. too big
Power Goals 200hp ish. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote"> a 50 trim t3.t04e would be just right for you. stage 3 turbine wheel with a .48 turbine housing.
Know of a place i can find one of those?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ape »</TD></TR><TR><TD CLASS="quote">Power Goals 200hp ish.
Know of a place i can find one of those?</TD></TR></TABLE>
Why would you want a 630 WHP capable turbo for a 200 HP setup?
The thing is im not going to keep the T25. So I need a new Turbo. I would like to get a T3 so i can upgrade the trubo later and still use the same mani when i have my other motor built.
Who is Mr Robot?
well, what all are you doing to the motor, how high are you going to turn it? once built what are your power goals? i can pretty much help you pick a good turbo if i have all this info and if icant help i can direct you to someone who can
I got a fresh rebuilt T3 for sale if your interested...
https://honda-tech.com/zerothread?id=1310078
have a gt28r for sale...would be awesome on a dseries...https://honda-tech.com/zerothread?id=1311487
Tippyman
Feb 28, 2007 07:46 AM
