Toyota's V-TEC?
Old Jul 16, 2005 | 04:39 PM
PreludeWA's Avatar
Default Toyota's V-TEC?
Found this sweet engine that toyota made called a '3sge'
200hp with vvti, 2.0L sounds like v-tec? did these guys copy it? i thought ford invented it.
http://www.tuning.cz/lander/beams.htm
Old Jul 16, 2005 | 04:54 PM
Pondus's Avatar
Default Re: Toyota's V-TEC? (PreludeWA)
Honda invented it and got a patent on the system, later on they decided to license it out to those willing to pay, i.e. Toyota.
Old Jul 16, 2005 | 05:13 PM
RudeBwaiSi's Avatar
Default Re: Toyota's V-TEC? (Pondus)
Toyota isn't the only company with a system similar to Honda's VTEC system. Mitsubishi has it (MIVEC), Nissan (VTC) to name a few.
Old Jul 16, 2005 | 05:15 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeWA &raquo;</TD></TR><TR><TD CLASS="quote">Found this sweet engine that toyota made called a '3sge'
http://www.tuning.cz/lander/beams.htm</TD></TR></TABLE>
ford? hahaha...
vvti equals self cam timing adjustment -
vvti-L has lift...
Honda found it, others bought it..
Old Jul 16, 2005 | 05:37 PM
Pondus's Avatar
Default Re: Toyota's V-TEC? (RudeBwaiSi)
Yes I know, but no one had it back in 1988 when the first VTEC B-16 was made by Honda, that's the origin of the technology.
Old Jul 16, 2005 | 06:24 PM
WhiteGSR95's Avatar
didint GM first introduce a the first version of it back in the 70s or 80s?
Old Jul 16, 2005 | 07:27 PM
projectTeG's Avatar
Default Re: (WhiteGSR95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteGSR95 &raquo;</TD></TR><TR><TD CLASS="quote">didint GM first introduce a the first version of it back in the 70s or 80s?</TD></TR></TABLE>
to my understanding honda didnt create vtec....i dunno who created it i just know honda didnt
Old Jul 16, 2005 | 08:01 PM
Slow EJ8's Avatar
I am pretty sure variable valve timing has been around since the 70's although I dont know who inveneted it but im sure it wasnt Honda. Honda has just marketed it the best and probably advanced the technology the most.
Old Jul 16, 2005 | 09:42 PM
hayabusa160's Avatar
Default Re: (Slow EJ8)
bmw have a pretty cooly system too..
Old Jul 16, 2005 | 10:42 PM
.john.'s Avatar
Default Re: (hayabusa160)
the first toyota vvt only controlled valve timing on the intake cam, but i guess the vvt-i controls lift as well. not sure, i just know the vvt on my 20v 4ag motor is oil controlled and simply advances cam timing at a certain rpm. the 3s has a similar oil controlled cam gear.
Old Jul 16, 2005 | 11:41 PM
xEnderx's Avatar
Default Re: (mr john)
vvti uses an oil pressure based system to vary the cam timing. I think it is self varying 15-20 degree's retarded or advanced. Systems like tha tuse inputs from all kinds of sensors. Lots of companies use timing adjustment and call it all kinds of crap like vvt-i, CVVT, etc. It is different from Vtec in that is DOES NOT have an induction (lift) adjustment...just timing. Vtec engages a second cam profile and is an on/off switch....timing adjustment systems vary a single profile in how its applied in relation to TDC and BDC.
If I am not mistaken Ivtec uses a timing maniuplation up to 50 degrees retard or advance as well as a three lobe camshaft to change lift profiles.
Old Jul 17, 2005 | 02:47 AM
gsp ej1-em1's Avatar
ive heard about ford inventing it too.. back in the late 80s , early 90s time period.
Old Jul 17, 2005 | 03:34 AM
StorminMatt's Avatar
Default Re: Toyota's V-TEC? (gsp ej1)
Then again, variable valve timing and VTEC are two completely different things.
Old Jul 17, 2005 | 04:37 AM
Flashmn's Avatar
Default Re: Toyota's V-TEC? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Honda invented it and got a patent on the system</TD></TR></TABLE>
If I remember correctly, Mercedes invented it in the 20's-30's
crxricer66
15
Aug 22, 2007 08:02 PM
tvman
Oct 31, 2005 07:08 PM
david90
Jul 13, 2004 03:24 PM
10K2HVN
12
Jul 23, 2003 06:21 AM
bearboy80
Apr 28, 2003 07:41 PM
