price of machine work.
Old Jul 16, 2005 | 03:08 PM
JDMorgan's Avatar
Default price of machine work.
i called up the machine shop that will be doing all of my bottem end work. the prices seem a bit high, on the other hand i relize it is a shitload of work. post how much you paid and what you done.
bore and hone cylinders, deck block, line bore mains, removing old pistons from rods, installing arp rod bolts, opening up itr pistons to fit non-r rods, installing new pistons on rods, sizing bearings, gapping rings, balancing assembly. the only thing he is supplying is the rod bolts. he said 1400-1600.
also does anybody know about a ball bearing that is pressed into the crank? he said they remove it for some reason, but i couldn't follow him on that. if anyone knows more about it, i would appreciate it.
Old Jul 16, 2005 | 09:25 PM
FIGARILA's Avatar
Default Re: price of machine work. (KraZEtEggIE)
ball bearing on crank ??? what kind of engine is this
TravisBiggie
Apr 10, 2013 08:21 AM
1995Civiccx
Feb 6, 2008 01:56 PM
egvtec
Dec 12, 2005 03:49 PM
max
Jan 21, 2002 10:21 PM
Trajic
Oct 8, 2001 11:00 PM
