Should I replace the crank bearings?
Old Oct 8, 2001 | 10:57 PM
Trajic's Avatar
New User
Default Should I replace the crank bearings?
OK I sent m y car to the shop to get some JE pistons and eagle rods to be installed. Im also changing the ehad gasket and the rod bearings but when we looked at the 3 crank bearings that u can see with out taking the block out they were chipped and worn so should i just replace all of them while im at it. And how much do u think they should charge me for this.
Taking out the engine
dropping in pistons and rods
replacing rod and crank bearings
new headgasket
they supplyed everything but pistons and rods
Old Oct 8, 2001 | 11:00 PM
VaporTrail's Avatar
New User
Default Re: Should I replace the crank bearings? (Trajic)
replace all the bearings, seals, and lower end gaskets. Do it right the first time so there is no second time. Oh, and make sure you use plastigauge
orioncivic
Aug 15, 2012 04:36 PM
GoldLudeRay
Sep 13, 2008 03:51 AM
1995Civiccx
Feb 6, 2008 01:56 PM
Yuleluder
May 14, 2003 03:42 AM
ill_take_one
28
Feb 25, 2003 09:00 PM
