T/B mount MAP used as firewall mount MAP... will it work?
Old Jul 15, 2005 | 07:59 AM
HybridKOOP's Avatar
Default T/B mount MAP used as firewall mount MAP... will it work?
Car: '98 Civic DX
Swap: B16A2 (JDM)
Obviously since it's a JDM swap, the MAP sensor is not mounted to the throttle body like its U.S. counterpart.
My question: Can I use a throttle body style MAP sensor, and simply run a vacuum line from the "nipple" on the MAP sensor to a vacuum source on the intake manifold? I would assume this will work but I just want to make sure.
Thanks.
Old Jul 15, 2005 | 10:16 AM
HybridKOOP's Avatar
Default Re: T/B mount MAP used as firewall mount MAP... will it work? (HybridKOOP)
Old Jul 15, 2005 | 12:26 PM
HybridKOOP's Avatar
Old Jul 16, 2005 | 04:15 AM
HybridKOOP's Avatar
Someone has to of tried this!
Old Jul 16, 2005 | 04:37 AM
machine4321's Avatar
i dotn see a problem with that ..just make sure the vac hose has a good fit on the nipple ...
Old Jul 16, 2005 | 09:04 AM
HybridKOOP's Avatar
Default Re: (machine4321)
Yeah, it has a perfect fit over the nipple... about to start the car for the first time tonight, I'll let you know how it worked... Thanks.
Old Jul 17, 2005 | 05:42 AM
HybridKOOP's Avatar
Default Re: (HybridKOOP)
This method DOES work for those who are interested in knowing.
Old Jul 17, 2005 | 03:42 PM
slomofo's Avatar
GDD Member
It's common sense, of course it works.
Edit: B16A2 is NOT jdm, firewall map sensors only came on older than dirt B16's.
Old Jul 17, 2005 | 03:53 PM
HybridKOOP's Avatar
Default Re: (slomofo)
Older than dirt B16's, huh?
Might want to check your facts again; and thanks for your 2 cents... it was extremely valuable.
Old Oct 16, 2008 | 07:58 PM
aj96coupe's Avatar
HybridKOOP....BURN!
Thanks, answered my question.
Munkeyd00d
Oct 3, 2011 07:20 PM
da9blk1
Jan 16, 2008 05:04 AM
dc2doi
Nov 9, 2007 12:16 PM
civichatch67
Sep 21, 2005 10:11 AM
