Ls vtech, What kind of power will i have?
Old Jul 14, 2005 | 01:42 PM
Penguinishblue02's Avatar
Default Ls vtech, What kind of power will i have?
Im debating on weather to take this b18b1 i have and do a ls vtech to it and put it in my 95 civic ex, I have a civic si b18 head, What kind of hp #s will i be getting here. I dont have alot of money to spend, so i would prob spend as little as possible. Will i have to buy any parts, minus the gaskets. And will it drop right in with the correct motor mts...any and all info on this subject would be appriciated. thanks..
Old Jul 14, 2005 | 01:46 PM
SixguN's Avatar
Default Re: Ls vtech, What kind of power will i have? (Penguinishblue02)
It vary's by so many things. You have a civic si b18 head?
Old Jul 14, 2005 | 01:48 PM
mwieczorek43's Avatar
Default Re: Ls vtech, What kind of power will i have? (Sixgundone)
Here we go again....
Im really confused as to what the hell you're saying first of all, but....
start here: https://honda-tech.com/zerothread?id=878010
Go from there.
Old Jul 14, 2005 | 01:52 PM
.:Swig:.'s Avatar
Default Re: Ls vtech, What kind of power will i have? (mwieczorek43)
got money for an lsvtec? is your civic going to be a daily driver?
Old Jul 14, 2005 | 01:55 PM
s2000june's Avatar
1st of all its vtec not VTEcH!!!
and your head is a b16 head not a b18 si's are 1.6 (b16) .
Best way to find out what u should or need to do go to search type ls vtec and you'll see what everyone else did or is doing and what kinda numbers they are puttin out. and you can get info on what you need . Golden eagle ls/vtec conversion kit for i.e
Old Jul 14, 2005 | 02:12 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Penguinishblue02 &raquo;</TD></TR><TR><TD CLASS="quote">Im debating on weather to take this b18b1 i have and do a ls vtech to it and put it in my 95 civic ex, I have a civic si b18 head, What kind of hp #s will i be getting here. I dont have alot of money to spend, so i would prob spend as little as possible. Will i have to buy any parts, minus the gaskets. And will it drop right in with the correct motor mts...any and all info on this subject would be appriciated. thanks.. </TD></TR></TABLE>
If you're on a tight budget (believe me, I can understand), I would probably stay away from the LS/VTEC set up. It's something you really don't want to cut corners with, and running out of money in the middle of a swap, or any car project for that matter, is the absolute worst. If you have a B16 head, and an LS block already, just save some money, do your research (thoroughly!), and map out your plan of attack when the time (and money) is right.
Old Jul 14, 2005 | 02:36 PM
jmcmil6's Avatar
Default Re: Ls vtech, What kind of power will i have? (rodrez.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">
If you're on a tight budget (believe me, I can understand), I would probably stay away from the LS/VTEC set up. It's something you really don't want to cut corners with, and running out of money in the middle of a swap, or any car project for that matter, is the absolute worst. If you have a B16 head, and an LS block already, just save some money, do your research (thoroughly!), and map out your plan of attack when the time (and money) is right. </TD></TR></TABLE>
DITTO.... you will save alot of money done once..done right
Old Jul 14, 2005 | 02:43 PM
MikeNice's Avatar
Couldn't have said it better
94Dc2Hatch
Nov 17, 2006 11:52 AM
pedrobabone
Nov 17, 2005 08:14 PM
es four
Aug 15, 2002 05:49 AM
baonest
Apr 21, 2002 07:05 PM
delsolracer
Jul 19, 2001 06:06 AM
