ls vtec ?
Old Nov 16, 2006 | 04:21 AM
94Dc2Hatch's Avatar
Default ls vtec ?
Juss lookin to see how much its goin to run me if i decide to run a b16 head on my ls n/v
Old Nov 16, 2006 | 05:09 AM
Racermech's Avatar
Default Re: ls vtec ? (94Dc2Hatch)
wow that is a very open qestion.
Do you allready have the head??
Do you want to do a full bild, or do yo jst want to do bare bones, meaning bolt the head on and just do what you have to do in order to get it running?
Old Nov 16, 2006 | 06:06 AM
94Dc2Hatch's Avatar
Default Re: ls vtec ? (Racermech)
im juss trying to get head n w.e else i need to get the most hp out of it
Old Nov 16, 2006 | 07:00 AM
DC2 Mang's Avatar
read through this thread, it has a bunch of excellent information
https://honda-tech.com/zerothread?id=1676914
read about the parts required and look up those prices, then add on any optional prices for upgraded parts to give yourself a general idea of how much it will cost to set up your engine
Old Nov 17, 2006 | 08:32 AM
gotJDM-DAteg's Avatar
Default Re: ls vtec ? (DC2 Mang)
The only way its going to be worth your while is if its a full build, otherwise it may not be very reliable, I know someone who just slapped a B16 head on an ls block, and he had constant problems. Just some advise. Plus you might be able to find a swap for as much as it will cost for the b16 head/ecu/ ls/vtec kit, ect.
Old Nov 17, 2006 | 08:48 AM
ivicr's Avatar
Every instance ive encountered with LSvtec has been pretty bad. When they work, they work well... The only problem is, most of the time LSvtec motors have probelem after problem. If you ask me, its not worth it.
Old Nov 17, 2006 | 09:07 AM
DC2 Mang's Avatar
Default Re: ls vtec ? (ivicr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivicr &raquo;</TD></TR><TR><TD CLASS="quote">Every instance ive encountered with LSvtec has been pretty bad. When they work, they work well... The only problem is, most of the time LSvtec motors have probelem after problem. If you ask me, its not worth it. </TD></TR></TABLE>
that is an uneducated comment, if built properly then an LSvtec is as reliable as any other motor
it is not different than building a GSR, B16, or LS motor. they only work as well as they are built, if you cut corners you end up with a motor that is alot of trouble. If you take time, do everything right then it will be a great motor
Old Nov 17, 2006 | 11:52 AM
96twofourty's Avatar
It depends on how much you want to spend. The more you spend the more reliable it will be
doood's Avatar
been there done that
im willing to bet the people that built those lsvtecs that had problems just slapped the head on the block and started abusing the **** out of it.
hatchyAllday
Feb 27, 2008 04:02 AM
pedrobabone
Nov 17, 2005 08:14 PM
LSBeast
18
Sep 27, 2003 10:47 PM
es four
Aug 15, 2002 05:49 AM
baonest
Apr 21, 2002 07:05 PM
