Misshifting?
Ok, Dont bag me on this. But i have a newb question. Say that you were shifting and goin fast but not flooring it. You meant to shift from 2nd to 3rd but you shift to neutral and it hit the rev limiter on rpm . Is this bad? Does it do any damage to the engine?
didnt you just ger your rsx?oh well, it will be fine so long as you dont do it too often, revlimiter like other people will keep you safe from stuff like that
drive the car for a while before you really get on it, I am not sure if the shifter bushing get broken in more or if i just learned the shift pattern alot better but it will get easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaziniflo »</TD></TR><TR><TD CLASS="quote">rev limiter is bad, but it's much better than misshifting to 10k and bending some rods. You'll be okay.</TD></TR></TABLE>
u bend valves more often than rods. rod's usually snap or fly through ur block.
