Engine Swap DIY???
Old Jul 13, 2005 | 09:32 AM
cubanSiR's Avatar
* B A N N E D *
Default Engine Swap DIY???
Im need to pull out my H22a out of my EK but ive never done it before. Is there a write on how to pull the motor out? I have searched but found nothing. Not everyone is born knowing how to do that..lol...
Any help would be appreciated.
Old Jul 13, 2005 | 09:39 AM
B6tPoweredMx3's Avatar
Default Re: Engine Swap DIY??? (ForceFed_h22)
Look into a some kind of manual for your car. Even though its not the stock engine it will give you an idea of how to go about pulling an engine. Make sure you label all of the connections too.
If you dont know what something is label it 1 and then label the other end 1 as well, so on and so forth.
Old Jul 13, 2005 | 10:00 AM
slomofo's Avatar
GDD Member
Drain fluids, pull axles, hook cherry picker on, unplug main harnesses, remove clutch slave cylinder, remove all coolant hoses/lines, unbolt motor mounts and lift it out.
Oh yeah, take exhaust off too.
Mr_ET
Honda Civic (2001 - 2005)
Mar 3, 2010 06:24 AM
hailchristian
16
Jul 11, 2009 04:39 AM
chadalac1712
Oct 30, 2007 05:45 AM
JUN.
21
Jan 31, 2006 08:52 AM
turbotime
16
Mar 10, 2004 05:12 AM
