throttle cable problem
ok... here's my problem.. i have a 00 civic with a gsr engine swap b18C1... So.. the cable for my gsr isn't fitting properly into the throttle body area... im not sure if im explaining myself properly.. so i have skunk2 manifold, and a elderbrock throttle body.. when i try and bring the gsr throttle cable around to the gsr bracket that i have, the cable is too long, and won't fit properly..i'd get less than 1/2 throttle.. so im trying to find a way to get my throttle to be able to open up all the way..one...person said that i should of got the ls throttle body and used that instead..another guy said that i should of use the type are bracket on the right hand side, and b16 throttle cable... can somebody with this same problem help me out, this siet is frustrating... if i did that b16 way wouldn't my throttle body be facing the wrong way... wutever..help!??
the throttle cable bracket is held on by two 10mm bolts. Just take off the bolts and move the bracket to the right so it is only held on by 1 bolt. problem solved.
Of course this is a cheap alternative if you don't want to change the cable.
96 GSR-T
May 10, 2006 01:24 PM
tegsallgood
Dec 18, 2004 12:14 AM
1SIKCRX
Jul 1, 2004 08:06 PM
