Need Info about OBD
Old Jul 12, 2005 | 02:01 PM
usafa2010's Avatar
Default Need Info about OBD
I just recently got a complete bottom end and the guy did not know which obd series it was all he knew is that it was a b16. My question is the difference between obd0, 1, and 2 engines. on the bottom and top ends. for instance say this is an obd0 block what would i need to do to change the block to obd1 to work with my cylinder head.
also can i tell by the number stamed on the block what year the engine is so i know what series.
Thanks
Modified by usafa2010 at 3:19 PM 7/12/2005
Old Jul 12, 2005 | 04:51 PM
PrettyLude's Avatar
usually they have stamps on the head to tell what year the motor was made
Old Jul 12, 2005 | 05:34 PM
slomofo's Avatar
GDD Member
OBD0 has nasty looking yellow colored plugs, OBDI and II have gray plugs. Only difference between OBDI/II are injectors, distributor, and one emissions sensor.
Old Jul 12, 2005 | 05:50 PM
usafa2010's Avatar
Default Re: (slomofo)
is there any difference between an obd0 an obd1 block
and where are the yellow or grey colored plugs located
Old Jul 12, 2005 | 06:27 PM
slomofo's Avatar
GDD Member
Default Re: (usafa2010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usafa2010 &raquo;</TD></TR><TR><TD CLASS="quote">is there any difference between an obd0 an obd1 block
and where are the yellow or grey colored plugs located</TD></TR></TABLE>
Look at the distributor, if the plug is yellow, it's OBD0, if it's two gray plugs it's OBDI, if it's one gray plug then it's OBDII.
Externally, OBD 0/I/II blocks are the same.
Old Jul 13, 2005 | 07:15 AM
iakona's Avatar
if it is a short block, it shouldn't really matter. like he said, externally, all OBD blocks are the same.
Old Jul 13, 2005 | 08:24 AM
usafa2010's Avatar
Default Re: Need Info about OBD (usafa2010)
awesome thanks for the help guys i love this site already
Old Jul 13, 2005 | 09:19 AM
PrettyLude's Avatar
one difference no one has mentioned yet, is that obd2 has the crank sensor in the timing belt area
Old Jul 13, 2005 | 09:28 AM
iakona's Avatar
right, but are those built into the oil pump? because the distributors are different too.
i also forgot to mention...
if this is an H block, there are closed decks for OBD1 and open deck for OBD2.
and then the rod journals are going to be bigger on the OBD2 crank.
Old Jul 13, 2005 | 12:38 PM
usafa2010's Avatar
Default Re: (iakona)
im just looking for the info on B series block mainly a b16 because i bought a complete bottom end and the only thing was that the guy didnt know if it was a obd0 or obd1.
also are there any negative side effects to getting a crank rebalanced and kinfe edged
Old Jul 13, 2005 | 12:49 PM
iakona's Avatar
also are there any negative side effects to getting a crank rebalanced and kinfe edged</TD></TR></TABLE>
don't take off too much material. why not just get it spin balanced and polished?
Old Jul 13, 2005 | 02:33 PM
usafa2010's Avatar
i did a search and realized its probably not a good idea to so so i am probably just going to get it ballanced
importtuner07
Oct 10, 2006 09:53 PM
jdmbeegee
Sep 5, 2006 09:30 PM
spooncivic1
Jul 27, 2006 04:57 PM
Lsssleeper Coupe
Mar 15, 2005 08:10 AM
teggytegteg
Nov 19, 2004 04:25 PM
