LS into 92-95 civic
Old Jul 10, 2005 | 04:01 PM
gutted-dx's Avatar
Default LS into 92-95 civic
I was wondering what wiring should be done and what mounts should be used, sorry i'm from the EF side
Old Jul 10, 2005 | 04:38 PM
e jay one's Avatar
Default Re: LS into 92-95 civic (gutted-dx)
i think the wire harness from the motor will work not too sure on that but heres the mounts.
Old Jul 10, 2005 | 06:19 PM
eg6ajk's Avatar
1) what year and type of LS swap is it?
- if 90-1 its complete PITA in EG, 92-3 is not much better but at least motor is OBDI <---- requires mount kit alond with hydro to cable tranny conversion, wiring changes and so on.... thus its not worth it and illegal in most states as well
-94-01 LS swap with hydro tranny is very straight forward, just get a complete motor/tranny along with shiftlinkage/mounts/axles - ECU can be optional, and harness as well (all depends on year of the swap and so on)
Old Jul 10, 2005 | 06:25 PM
chelsietyper's Avatar
very easy and cheep swap just finished one u can use all oem honda mounts
i wouldnt recomend it though unless ur gona do turbo or lsvtec good luck dude
Old Jul 10, 2005 | 10:28 PM
gutted-dx's Avatar
So if i used a OBD1 LS it would plug up and i would use the mounts from the integra also
Old Jul 13, 2005 | 09:16 AM
gutted-dx's Avatar
bump
Old Jul 13, 2005 | 09:55 AM
LShatchie's Avatar
Default Re: (gutted-dx)
I have a 0bd0 b18a1 in my 93 civic, its not that hard to convert it to obd1... basically you just need to swap a few parts with obd1 parts like distributor, ecu, injectors and maybe a few other things im missing.
Old Jul 13, 2005 | 11:05 AM
gutted-dx's Avatar
I have a 94 b18b1 i am going to be swapping it into a 93 hatch would wiring would i need
Old Jul 13, 2005 | 08:31 PM
go2sleep's Avatar
i was told the ls is the same as the civic wiring (dx) not to sure of the cx.
Old Jul 21, 2005 | 05:26 PM
gutted-dx's Avatar
Can anyone confirm
Old Jul 21, 2005 | 06:54 PM
D16Z6_turbo's Avatar
Default Re: (go2sleep)
It'll be an easy drop in with that 1994 B18b. The harness from the motor will be plug-n-play and use the mounts, axles, and shift linkage from the Integra.
preetyboi06
Jul 17, 2009 09:57 AM
Spoolind16
Oct 18, 2006 08:31 PM
fullboostin
Jul 21, 2004 04:13 AM
BluntMan
Jan 11, 2003 05:53 PM
mycvc8u2
Jan 5, 2003 12:18 AM
