B18A swap in EG civic
Old 07-20-2004, 08:13 PM
fullboostin's Avatar
Default B18A swap in EG civic
Im getting ready to do a swap in my eg hatch. Im eventually going to do an ls/vtec setup but for now just swapping the ls motor. Wanted to know if the mounts are the same and if im going to be able to use my stock wiring harness.
Also looking for a hydro tranny for this setup if anyone knows of anything
Old 07-20-2004, 08:18 PM
ABK
ABK's Avatar
Default Re: B18A swap in EG civic (fullboostin)
mounts are not the same (search). For tranny you can use any b series tranny, look for a b16a2 good gears.
Old 07-20-2004, 08:51 PM
Default Re: B18A swap in EG civic (ABK)
wont the stock mounts from the integra work ?
Old 07-20-2004, 09:03 PM
Andres-eh2's Avatar
just did this swap. i used the cx harness on the obd1 b18a. lengthened some wires, wired up the four wire o2 and its done!
Modified by Andres-eh2 at 11:49 AM 7/21/2004
Modified by Andres-eh2 at 11:50 AM 7/21/2004
Old 07-21-2004, 12:56 AM
civtegra_hybrid's Avatar
it will fit right in just use your stock mounts, the only thing you have to change is the bracket that's on the eng. that goes to the driver side mount, to a new one, off an integ. 94-00 and it will work, already did it.
Old 07-21-2004, 04:13 AM
Sliced Beard's Avatar
Default Re: B18A swap in EG civic (civtegra_hybrid)
teh d series tranny mount will work on a hydro tranny (stock 92-95 tranny mount)
the reart mount is the same and the drivers side upper is the same (it has to be the 3 hole mount)
the only thing you will need to get is the torque mount brackets and teh rear mount bracket (it looks like a funky L or funky T)
and a good tranny to get that will mekt the LS fun swap is a B16 tranny or an ITR tranny
revikan
19
10-01-2012 06:56 AM
xxEG6xx
11
04-24-2011 03:54 PM
drowzysleeper
09-24-2006 10:40 AM
gutted-dx
10
07-21-2005 06:54 PM
seeeya04
06-06-2005 06:06 PM
Quick Reply: B18A swap in EG civic
