Is my compression good or bad.
Honda Civic VX 95 w/D15Z1
Did my comression test and this is what i got.
151, 152, 153, 150
Here alot of things about seafoam and finally give it a try. And now this is what i got.
165, 165, 160, 165
I don't know much about compression ratio or what the stock number suppose to be. So are these number good or bad.
151, 152, 153, 150
165, 165, 160, 165
your not really looking for a highger number as much as you are looking for continuity between all the cylinders, Depending on the comp ratio you could get low numbers, but since your numbers are all within 5 of each other seems fine.
As for a higher comp after seafoam that seems like it should be the opposite lower after seafoam. Per cleaning out combustion that usually bumpsthe comp up a bit.
HOw many cranks did you do, throttle =wide Open?
usually 5 or 6 cranks is sufficient for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_Black_Hatch »</TD></TR><TR><TD CLASS="quote">your not really looking for a highger number as much as you are looking for continuity between all the cylinders, Depending on the comp ratio you could get low numbers, but since your numbers are all within 5 of each other seems fine.
usually 5 or 6 cranks is sufficient for me.</TD></TR></TABLE>
Oh **** you were suppose to crank it with full throttle. Btw it crank it 5 times.
read this http://www.c-speedracing.com/h...t.php
you might if skipped a step
