Quick question re: turbo oil supply and oil return lines
Im piecing together a kit for a D-series turbo build using a T3 45 trim (.42/.48) turbo.
What size -an lines should I be using for the oil supply and oil return lines? Not sure if it matters, but I will be using a oil sandwich plate for the oil supply....
Thanks
Thanks
I agree with tdocrx.
Also, when using the Golden Eagle sandwich adapter, use the GVC100-18 (two 1/8NPT ports) if you are wanting to run turbo and an aftermarket gauge, or run the GVC100-6 (one 1/8NPT and one -6 AN) if you are doing an LS/VTEC or something similar where you need to use oil pressure to activate VTEC.
Craig
Craig
Anyone have a good number for the length of the supply line?? Im at work, and cant measure and the moment....
