will she BLOW>>>>IF YOU DONT KNOW YOUR SHIT DONT BOTHER LOOKING
my type RSX-S has got a greddy turbo kit ,greddy e management system, 440cc injectors, and a bbk fule rail..HOW Many pounds till she blows???.....greddy exhaust...and manual boost controlor
From: Holley 4053, carb 406 stroker anal Luber, Fag
im going to tell you 14psi. mainly because I don't like your attitude you man *** loving bitch.
Who is Mr Robot?
how bout you turn up the boost controller and find out
and which FUEL rail(spelling you tard) do you have, str or bbk. you keep on changing your setups in other threads
Apparently YOU don't know your ****, so die.
EDIT: What you should do is drive the **** outta it un-tuned first, if it doesn't blow then, rinse and repeat until your car is chuggin oil, THEN die.
With your 440cc injectors it'll be max out @ about 350hp and if it's untuned it'll blow even if it's all motor but if it's tuned your injectors will max out even before you pass your piston&rods limits.
Sleeping4drLS
68
Feb 24, 2003 10:53 AM
