my sohc 15G greddy kit question....
Old Jul 8, 2005 | 11:26 AM
my93hatch's Avatar
Default my sohc 15G greddy kit question....
You might have to read it all to understand what i'm talking about..
I understand that the greddy kit comes stock at 5.5psi. Does that mean the wastegate is set at 5.5psi? If i turned up the boost with a manual BC to say, 7.5psi, does that mean my wastegate is now set at 7.5psi??
I question this because i hear talk about people saying their wastegate is set for example at 8psi, does that mean they just put a BC on a turned it up or are they acually doing something to the wastegate itself along with installing a BC and turning that up too????
I'm gonna be doing a swap soon so i'll be wanting to turn the boost up a little and i'm not sure if i have to do anything with the wastegate....?
I appreciate your help, thanks!
Old Jul 8, 2005 | 02:21 PM
Cee_mon's Avatar
Default Re: my sohc 15G greddy kit question.... (my93hatch)
EASY NOT TECHINCAL ANSWER
The boost controller will limit the amount of pressure on the wastegate. On your internal wastegate the BC will bleed off pressure to make your wastegate think its at 5.5.
So you dont adjust your wastegate the BC will do it on its own.
Old Jul 8, 2005 | 03:17 PM
1boostedcivic's Avatar
Default Re: my sohc 15G greddy kit question.... (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">EASY NOT TECHINCAL ANSWER
Old Jul 8, 2005 | 03:19 PM
my93hatch's Avatar
easy enough...thanks!
Old Jul 8, 2005 | 07:15 PM
mike93eh
Guest
Posts: n/a
yup just hook the bc up and turn it up.
Old Jul 9, 2005 | 07:20 AM
my93hatch's Avatar
just curious, about how much boost is this greddy kit good for???
Old Jul 9, 2005 | 07:42 AM
Default Re: (my93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my93hatch &raquo;</TD></TR><TR><TD CLASS="quote">just curious, about how much boost is this greddy kit good for???</TD></TR></TABLE>
260-270 17-19psi on hondata/chrome/uberdata/turboedit
Old Jul 9, 2005 | 09:18 AM
norcalcrx's Avatar
Default Re: (1boostedcivic)
250 @ 10-11 psi here. Im shooting for 300+ on my new motor......just to see if it can be done.
Old Jul 9, 2005 | 09:30 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic &raquo;</TD></TR><TR><TD CLASS="quote">260-270 17-19psi on hondata/chrome/uberdata/turboedit</TD></TR></TABLE>
your on 19 psi with a 15g??
Old Jul 9, 2005 | 10:40 AM
Default Re: (mike93eh)
no. But i heard of people running 18 pounds on the saab t3 which is smaller than the greddy 15g.n so i would suspec that turbo can handle that. but im not sure.
Im running a T3 60ar 63x 60 trim
Old Jul 9, 2005 | 10:58 AM
LoSt is BlaCk's Avatar
Default Re: (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">250 @ 10-11 psi here. Im shooting for 300+ on my new motor......just to see if it can be done.</TD></TR></TABLE>
i want your tune ASAP!!! those are solid freak'n numbers
Old Jul 9, 2005 | 02:55 PM
urbansi's Avatar
Default Re: (LoSt is BlaCk)
yeah i am with you on that too. i am getting my car tuned with uberdata next week@10psi and i am hoping to see around 215-225 hp on a b-series with an 18g.
Old Jul 9, 2005 | 10:48 PM
Default Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">yeah i am with you on that too. i am getting my car tuned with uberdata next week@10psi and i am hoping to see around 215-225 hp on a b-series with an 18g.</TD></TR></TABLE>
you should do better then 215 with 10psi
Old Jul 9, 2005 | 11:22 PM
urbansi's Avatar
i am hoping so too. i have seen lots of greddy guys really disapointed though so i am actually hoping to be over 200whp. pretty das for 10psi huh?
Old Jul 10, 2005 | 06:35 AM
91integraLSVTEC's Avatar
ive used a ebay MBC and it would not control the boost, it would over boost the engine no matter where i hooked up the vaccum source. now i just use the waste gate locknut to control boost.
Old Jul 10, 2005 | 08:18 AM
mike93eh
Guest
Posts: n/a
Default Re: my sohc 15G greddy kit question.... (91integraLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">ive used a ebay MBC and it would not control the boost, it would over boost the engine no matter where i hooked up the vaccum source. now i just use the waste gate locknut to control boost.</TD></TR></TABLE>
there's your problem..
Old Jul 10, 2005 | 08:55 AM
urbansi's Avatar
Default Re: my sohc 15G greddy kit question.... (mike93eh)
i have an ebay special boost controller on my car and it holds boost strong, bery little creap and actually made it spool a little faster imo. i know tons of people that make or buy mbc's and i rarely hear bad things about them. dont diss them untill you have used one
xander1100
Jun 27, 2009 10:56 AM
chilli_822
Jul 25, 2008 03:02 PM
2muchPSI
Oct 19, 2003 07:07 PM
pelotudo
Aug 21, 2002 07:36 PM
