My First Logs for my JRSC Install
Old Jul 8, 2005 | 04:07 AM
98BlackTeg's Avatar
Default My First Logs for my JRSC Install
I would like to share my first AEM EMS logs after initial self street tune. Please check out http://intraweave.com/myteg/about.htm to what I have installed. I will getting it dyno tuned next weekend so any comments would be welcome.
and with injector duty cycles
Old Jul 8, 2005 | 07:33 AM
EJ1 wilcox's Avatar
Default Re: My First Logs for my JRSC Install (98BlackTeg)
What are we looking at?
RPMs, MAP, AFR?
You need to make some WOT pulls to really see where you are at so you can fine tune. I tried to find some pulls in there but the lines are so jumpy.
It might be easier if you took just one pull and expanded it, instead of 8+ minutes of driving in one picture.
It looks like your air fuel ratios are pretty close to 12:1 while in boost but it's hard to tell without looking closer.
Old Jul 8, 2005 | 07:37 AM
JDMisGOOD's Avatar
Just do ONE WOT pulls at a time so you can actually read the logs
Old Jul 8, 2005 | 02:43 PM
98BlackTeg's Avatar
Default Re: My First Logs for my JRSC Install (JDMisGOOD)
I ran a single constant load run, but the computer's battery died before I had a chance to save.
Does it look safe enough for a 2 hour drive to the tuner?
Old Jul 8, 2005 | 07:11 PM
98BlackTeg's Avatar
Zoom in of 1 section. It might help.
Old Aug 23, 2005 | 10:42 AM
ruthless013's Avatar
nice write up on your site, i may use the info someday.
are the numbers on the dyno about what you expected? i'm not familiar with jrsc's on your motor, but i would have thought you'd be making more power.
Atrus
Mar 25, 2005 10:33 AM
Azcheron
Aug 21, 2004 01:52 PM
Azcheron
Aug 12, 2004 12:06 PM
Luchini
Mar 24, 2004 11:57 PM
MooreBoost
Jul 8, 2003 03:28 PM
