dsm injectos install on hondata.net?
isnt there write up on that page complete with pics and all? i cant find it. i need to know about the wiring. all i found is that the bluetops wont work on the hondata site? huh
Who is Mr Robot?
thats right. dsm injectors will not work with hondata, something about the electrical characteristics of the injector
search is precious. Only took me 5 seconds to find this
https://honda-tech.com/zerothread?id=1188840
To make the injector work with obd1 clip, take a coat hanger, cut a piece about six inches long. Heat up one side, almost to glowing red, and melt the little tab that sticks out in the middle of the injector. Sorta like this, the dot is the part you need to melt away [ . ]
to get the injector into the fuel rail, put a little vasoline on the seal, force the injector in with your hand as far as you can. Do this for all four. Then put the fuel rail and slowly tighten down, switching from one bolt to another. This will force the injectors into the seals.
it works... i have hondata S200B with DSM450cc injectors and no complaints.... simply perfect ! so whoever says it cant be done... i dont know what they are talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">thats right. dsm injectors will not work with hondata, something about the electrical characteristics of the injector</TD></TR></TABLE>
huh? If you can use big 1000cc peak and hold injectors with hondata then i'm sure you could use dsm injectors.
Who is Mr Robot?
check hondata's site. its what they tell you. theyve had problems idling, running lean at part throttle, etc
Who is Mr Robot?
Thats total BS. I've never had any problems tuning with DSM injectors. My car runs smooth like a stock car with them and they haven't been any harder to tune than some rc saturated 440's.
Tunerrr
Mar 30, 2011 08:18 PM
[edit]
