battery???
well when I started my car today noticed that when I reved my car a little the rpms would go up and when they came back down it went real low and almost wanted to die and the lights would dim. So I left my car running and disconnected my battery and it still ran which would mean the alternator is working fine (correct me if I am wrong.) So is this an early warning sign that I need a new battery or is this a total different problem? Any help would be great.
I dont think it could be a vaccum leak because my idle is normal its just after i rev it it drops down real low then returns to normal idle i heard (CORRECT ME IF I AM WRONG) that a common problem is your idle will go up and down repetadily if you have a vaccum leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto »</TD></TR><TR><TD CLASS="quote">check for a vacuum leak</TD></TR></TABLE>
+1
+1
If the lights dim when the car revved down then it can't be a vauum leak, most likely its your battery or alternator thats about to go. Have you checked your ground connections? Make sure they're snug as well.
