H22 EG no start
Old Jul 7, 2005 | 04:56 PM
EssEg's Avatar
Default H22 EG no start
well iv been workin on this we about 5 days.....its almost done, I have a 92 eg with a obd 1 h22a, euro r manifold. Every thing is in.....but I have the header open, no 02 hooked up right now, and I odnt have an air temp sensor, hasnt come in yet. For ***** and giggles I thoguth id try startin it tonight, just pops and tunes over. both motors were external coils, I have the injector resistor in, no evap stuff, im runnin a chipped p28 with uberdata, im 99% sure I have firing order right, and I checked timming about 100 times before I put the motor in....im gettin fuel....plugs were wet, im sure im gettin spark, its popin like its firein....should I jsut wait till its complete? I just dont wanna finish it and then have to take **** back apart, what do you think?
Old Jul 7, 2005 | 04:59 PM
Dragline's Avatar
Default Re: H22 EG no start (EssEg)
Is it poping through the throttle body.
Old Jul 7, 2005 | 05:16 PM
EssEg's Avatar
Default Re: H22 EG no start (dragline)
the header
Old Jul 7, 2005 | 05:30 PM
WickedSol's Avatar
check your engine/harness grounds....also check TPS & Map sensors....is the motor on TDC?
Old Jul 8, 2005 | 07:13 AM
Honda Sport's Avatar
ignition timing may be off. your firing order could be wrong also. I had this happen to me. firing order 1342
Old Jul 8, 2005 | 07:55 AM
Local Tuner's Avatar
Default Re: H22 EG no start (SpdImge415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdImge415 &raquo;</TD></TR><TR><TD CLASS="quote">check your engine/harness grounds..</TD></TR></TABLE>
Old Jul 8, 2005 | 11:15 AM
IHateJDM's Avatar
Default Re: H22 EG no start (Local Tuner)
compression test?
JDM_CAM
Mar 24, 2012 04:52 PM
djnikko
May 12, 2009 08:38 AM
roberts88
Jan 1, 2009 07:49 AM
SoOHiGH
May 30, 2005 02:50 PM
probert
Jun 30, 2004 01:43 PM
