Nitrous???
Old Jul 7, 2005 | 12:38 PM
Ben_si's Avatar
Default Nitrous???
I was thinking about doing a zex efi dry 50-75 shot. Is that a bad idea i read up on it and it seems pretty safe as long as you use colder plugs.
Old Jul 7, 2005 | 12:41 PM
jameskersten1's Avatar
do the proper things like compression test to make sure your motor is capable. run a 2 step colder plug, set your timing right and run higher octane gas, and you should be fine. i recommend using a msd window switch so you dont risk bouncing off the fuel cut.
99hondacura
Feb 25, 2007 11:32 AM
SiR831
Jun 28, 2005 10:19 AM
dpw41285
Feb 18, 2005 07:56 PM
2SlowAccord
Jun 11, 2003 08:21 PM
MikeMAN
Aug 21, 2002 02:34 PM
