nitrous set up
Old Feb 14, 2007 | 07:32 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
Default nitrous set up
im building a all motor setup but i want more power how much nitrous shot can a motor built wit 13:1 compression hold? just a question if it cant hold alot then ill probably wont do it
Old Feb 14, 2007 | 07:01 PM
jsw_1986's Avatar
Default Re: nitrous set up (99hondacura)
stock internals, I probably wouldn't have more than a 75shot to be safe.
Old Feb 15, 2007 | 08:11 AM
no no stock internls everything is going to be aftermarket nothing is going to be stock on the motor
Old Feb 15, 2007 | 09:11 AM
92redhatch's Avatar
150 shot with a good tune.
Old Feb 15, 2007 | 10:05 AM
SIXTY-1HATCH's Avatar
Default Re: (92redhatch)
thats sumthin we can't really answer for you depends on your tuner........
your gonna want sumthin that will pull timing like a msd digital 6 or sumthin that will pull timin from the motor when be sprayed.
BUUUTTT hi compression cars LOVE nitrous so who knows id say around 100 shot though
Old Feb 15, 2007 | 10:55 AM
92redhatch's Avatar
i know people on a 100 shot on a stock motor. Ive even seen 100 shot on an automatic sohc.
Old Feb 17, 2007 | 10:33 PM
BuiltforSin's Avatar
how many shots did that last?
Old Feb 17, 2007 | 10:37 PM
96vtecI4's Avatar
buy an RPM window switch, wet kit, don't spray in high rpm's colder plugs, good tuning and you should get away with 150.
Old Feb 20, 2007 | 07:49 AM
ku ku thanks yea i think ama spray like a 100 shot of nitrous in this build just to give the turbo cars a surprise you kno!! thanks for the info guys
Old Feb 20, 2007 | 08:15 AM
nonvtecallmotor's Avatar
Default Re: (99hondacura)
Most of the time you can go just as fast with a smaller shot, but it all depends on your set up, tune and octane. I've done set ups from 40 - 200+shots. All the set ups needed to be tuned diff.
Old Feb 25, 2007 | 10:56 AM
v.i.gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">i know people on a 100 shot on a stock motor. Ive even seen 100 shot on an automatic sohc.</TD></TR></TABLE>
I have run a 125 shot on my stock gsr.
2-step colder plugs ngk
pull 6 degrees timing
bump up fuel pressure some.
on a stock p30 ecu.
she still is running strong
Old Feb 25, 2007 | 11:32 AM
zexxbo's Avatar
Default Re: (v.i.gsr)
if the block is going to be sleeved and youre running forged pistons and rods, you can run up to about 180shot. now if youre going to be driving this on the street at all, i would think more about going with like 125 shot on itb's, if you have the money or are gonna track it, i would do the direct port to itb's
tempsohc
15
Mar 11, 2011 06:08 PM
8083tcman
Jan 16, 2009 11:56 AM
SiB16A
Jan 17, 2004 02:15 AM
Audio28
Dec 7, 2002 11:23 AM
EEK
Jun 4, 2002 09:01 AM
