knock sensor
Old Feb 14, 2002 | 09:26 PM
importneeds's Avatar
Default knock sensor
I DID A SWAP ON MY 94 CIVIC EX AND PUT A 94 GSR THE CHECK ENGINE LIGHT CAME ON FOR THE SENSOR AND I REPLACED THE SENSOR BUT THE LIGHT STAYS ON. DOES ANYONE KNOW THE PROBLEM?
Old Feb 14, 2002 | 09:49 PM
salbaje's Avatar
Default Re: knock sensor (importneeds)
maybe you didnt wire it in right. where did you wire it in?? what kind of harness you using??
Old Feb 14, 2002 | 10:54 PM
I USED THE STOCK GSR WIRING HARNESS
Old Feb 15, 2002 | 01:47 AM
Katman's Avatar
you might of used the GSR engine harness, but did you wire up the knock sensor from the ECU to the shocktower wire harness? there's bridge you haven't gapped yet. Another option is getting your ECU reprogrammed to NOT look for the knock sensor, but I don't suggest an ECU upgrade if you don't plan on getting a camshaft upgrade...
crxb16ftw
May 23, 2007 09:32 PM
EG civic
Jun 17, 2006 10:05 PM
GR_DC2
Mar 9, 2006 12:29 PM
DRTYHARRYIII
Jun 6, 2003 09:46 AM
